Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-23-2012, 02:41 AM   #1
zellway
zellway's Avatar
Ol Blue
Well for starters this is going to be hard for me as I have never had this clean of a start. I want to take this back to more of a stock look. Might drop it a bit more and put the stock wheels and caps back on it. I will be getting new tail lights as the PO felt the need to black them out. It has a good working under dash a/c system but with the AZ heat that might not work out so well. I just want to driver this one. I just picked it up about 3 hours ago. Drove it from Tucson with no problems and only used 1/8" a tank (that is if the guage can be trusted) It need most of the rubber replaced. I found some small spots of rust in the normal spots. From what I can tell its stock paint. It drives like a new truck. The PO had a local shop install the drop coil's and a full front end kit so there is almost no play in this thing. I don't know if this will be much of a build as much as just a fresh up and drive. But I will do my best to post pic's of what I get done on it. When the sun is back out I will get some more pic's.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 06-23-2012, 07:57 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Ol Blue
Cool burb zellway!!!...any SPID shots? how about interior?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-23-2012, 09:46 AM   #3
zellway
zellway's Avatar
Re: Ol Blue
Its funny that you ask. I looked all over this thing when I got it and never once opend the glove box. Check out what I found.
Erik
Old 06-23-2012, 09:51 AM   #4
zellway
zellway's Avatar
Re: Ol Blue
More pic's
Erik
Old 06-23-2012, 09:56 AM   #5
zellway
zellway's Avatar
Re: Ol Blue
I will try and get a good set of pic's on this one. I could kick my self for all the stuff I have not taken pic's of.
Erik
Old 06-23-2012, 09:57 AM   #6
zellway
zellway's Avatar
Re: Ol Blue
The outside has some old faded blue paint over the stock teal. Should be fine for what I want. It's a good looking ride IMO.
Erik
Old 06-24-2012, 03:32 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Ol Blue
Sweet!!...Thanks for the pics!!!
Geoff with a G
Old 06-26-2012, 08:56 AM   #8
zellway
zellway's Avatar
Re: Ol Blue
Monday I got to spend a part of my day at the DMV to get my new plates for Ol Blue. The nice thing is the tags are good till 2016! So I walk out all happy and ready to put my plate on and found out the hack job of a trailer hitch blocks the bottom of the plate. So I had to decide to cut 1 1/2" off the bottom of my plate or remove the hitch. Well not much thinking and I got back to the shop and took the plasma cutter for a test drive. Fixed my plate light and called it a day. This weekend I will clean up where I cut and paint the end of the frame. There is a little more play then I would like in the carrier bearing so I will be pulling the drive line this weekend. I'm going to do my best not to down Ol Blue like I have will all my other trucks I want to keep driving.
Erik
Old 06-27-2012, 02:02 PM   #9
Green 1959
Green 1959's Avatar
Re: Ol Blue
That looks like a really nice shop you are cutting the hitch off at!
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 06-27-2012, 03:45 PM   #10
zellway
zellway's Avatar
Re: Ol Blue
Yep! You would know!
Erik
Old 07-02-2012, 07:34 AM   #11
zellway
zellway's Avatar
Re: Ol Blue
Well not much has been done this past week. I put about 200 miles on it in the AZ heat with no problems. A/C works great for the people in the front seat but something will need to be done if I want people to ride in back. I have been feeling a little shake at 65mph to 75mph and found the center bearing rubber was gone. I replaced it and check out the under side a bit more. Not much is going to be needed.
Erik
Old 07-05-2012, 09:47 AM   #12
Green 1959
Green 1959's Avatar
Re: Ol Blue
It looks a lot better
Old 07-09-2012, 08:35 AM   #13
zellway
zellway's Avatar
Re: Ol Blue
Worked on cleaning it up this weekend. I also changed the oil. Took it on a trip to Tucson. 172 miles round trip in the heat with no problems. Vent window seals are high on my list of things to do! Got a chance to work on my other toys this weekend.
Erik
Old 07-13-2012, 06:08 AM   #14
zellway
zellway's Avatar
Re: Ol Blue
I got a little done but work takes up most my time any more. I will have some big stuff going on in the next few weeks. I have a bunch of the small parts on there way. I removed the black paint from the hood bow tie and repainted the center blue. I looking into some the tires for the stock wheels and I have a set of hubcaps I will clean up and get on.
Erik
Old 07-18-2012, 11:53 AM   #15
zellway
zellway's Avatar
Re: Ol Blue
With work as crazy as it has been I don't get much time to work on my stuff. I popped the bowtie back on the hood and I removed the grill and started to get the paint off it. I will work out the few little dents and get this back on. Should look about how I want it to. I'm also looking into cleaning up the stock wheels and get some tires for them.
Erik
Old 07-24-2012, 12:07 PM   #16
superduty_59
Re: Ol Blue
Nice work, I'm not a fan of black everything out either.
superduty_59 is offline   Reply With Quote
Old 07-25-2012, 10:46 PM   #17
Green 1959
Green 1959's Avatar
Re: Ol Blue
Looking better. Should be nice when it gets together!
Old 08-01-2012, 09:38 AM   #18
zellway
zellway's Avatar
Re: Ol Blue
I have new found appreciation for people that paint all the detail around there grills! I have spent more time then I had planed on. I was going to sand down and do the full show type polish but for a driver I think this grill is fine. I worked a little bit out of the dent around the E but for fear of messing it up I called it good. I will get it painted after work then to cote it in UV clear to save the look of it. Should have it all back this weekend so I can take Ol blue out for a drive.
Erik
Old 08-01-2012, 07:32 PM   #19
zellway
zellway's Avatar
Re: Ol Blue
Well its much better looking then when I started so I'm happy. I will get this back on this weekend. It's a good 10 foot job but will look at home on it. Now on to cleaning up the engine bay.
Erik
Old 08-06-2012, 08:37 AM   #20
zellway
zellway's Avatar
Re: Ol Blue
I like this look much better. Soon as I have the brackets done the bumper will go back on.
Erik
Old 08-06-2012, 08:40 AM   #21
zellway
zellway's Avatar
Re: Ol Blue
I knocked off a little of the dirt and more of the paint then I wanted. I also ditched the points.
Erik
Old 08-06-2012, 05:30 PM   #22
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Ol Blue
The grill made a huge difference. Nice work!
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-13-2012, 08:24 AM   #23
zellway
zellway's Avatar
Re: Ol Blue
Took a trip down to Tucson this weekend to pick up a new rear axle for my 67 from Oilyrag80. Did good in the heat. It runs great on the highway. Got all kinds of looks from people as I passed. A/C is a little weak but it was about 112 and the seals are not the best in the cab but it kept up. If you trust the GPS speedo apt my guage is only off a little bit. Don't ask how I got that pic. It was not EZ.
Erik
Old 09-26-2012, 10:43 AM   #24
zellway
zellway's Avatar
Re: Ol Blue
Well its been some time with no updates. I have been putting some miles on the old burb and enjoying having a driver. I dropped it off down in Tucson to get the seats redone. I can't wait to get it back. I will post pic's soon as I get it back next week. When I get it back I will get to work replacing more of the rubber goods around the windows.
Erik
Old 10-11-2012, 08:31 AM   #25
zellway
zellway's Avatar
Re: Ol Blue
Not done yet but looking good. The pic's do not show how cool the seats are in person! I'm vary happy with how they look and feel! They are going to cover the dash pad. Should be getting it back Monday.
Erik
