"Bittersweet" 83 dropmember blown LS 22s
This is my latest project it's well on its way
Posted via Mobile Device |
Re: "Bittersweet" 83 dropmember blown LS 22s
Looks clean. Specs? Plans?
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
Truck has front and rear porterbuilt drop members ls1 with heads cam magnacharger and its sitting on 22" billetspecialties turbine rims
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
Nice! Keep the pics coming and maybe go ahead and include a couple of that F-- d in the background.
Frank Posted via Mobile Device
Born and proudly residing in a Red State ! |
Wow - looks great!
I have one question though - I might catch hell from all the guys with bagged squares - I only ask because I've had experience with hydraulics, not airbags - but can you really take advantage of a huge HP engine, whether an LS or not? I mean, isn't there some diminished handling characteristics with airbags? So isn't all that monster HP kinda wasted?
![]() Join Date: Feb 2012
very nice truck
#11 | |
Airbags = great stance nice ride and moderate handling Springs = harsh or soft ride. Moderate stance great handling when setup that way and a good stance with about the same fab as bags Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#12 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Any Porterbuilt chassis has a lower ride height than my bagged blazer at full dump.
heres a few shots of the bed
i went with new bed sides front wall and gate and the crew at rpm designed and did the metal work inside
#15 | |
#16 |
i took a few pics today theres a shot of the mac's track that flush mounts into the bed , not sure if ill have them polished or powercoated yet
a pic of the gas cap and the boxes RPM made to go in the fuel doors left side is air fitting to fill the tank kinda back up and a air gauge to show tank pressure and the right side is battery jump terminals and flaming river kill switch and those are painted flat like the engine bay will be |
#17 | |
Airbags or steel Springs = harsh or soft ride depending on how they're set-up. Moderate stance & great handling can be achieved w/either spring type again depending on how they're set up. Steel coils can be set up w/a good stance (ride height) with about the same fab as bags but won't have the same adjustability.
#18 | |
You need to get that engine started for us and post a vid! Posted via Mobile Device
#19 |
With air bags the more psi in the bag the higher the spring rate gets.Handling can be better with air bags if its set up right,Ridetech took a 4th gen camaro and ran it down a slalom bone stock then put their air ride kit on it and ran it again.The air ride one did better times.
#20 |
Killer work,... like always,... from the guys at RPM.
#21 |
heres the bed complete
#22 |
That's one of the nicest beds i seen on here in a while.
#23 |
Sweet! Like the bed fabrication but what is the hole in the middle of the notch and the rear slots for?
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#24 |
Sold! 2 days after finished
Gas cap....
#25 |
Sick.
What's the deal w/ that Bronco in the background? Looks interesting. |
