09-29-2020, 01:02 PM | #1 |
LED instrument lights
Has anyone had any luck converting the instrument cluster lights to LED? I have been looking but I don't know what is compatible for our harness. Help please. My truck is a 70.
Thanks |
09-29-2020, 01:33 PM | #2 |
Re: LED instrument lights
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
09-29-2020, 02:31 PM | #3 |
Old member
I have done 3 dashes with these LED bulbs and they work great.
https://www.youtube.com/watch?v=vRZLojkRjNw https://www.youtube.com/watch?v=DPXrJSpJq5U ENDPAGE 194 LED Bulbs Canbus Error Free 6000K Xenon White Super Bright 2835 Chipsets 168 2825 175 T10 W5W LED Replacement Bulbs for Car Dome Map Door Courtesy License Plate Lights(Pack of 10)
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-29-2020, 07:20 PM | #4 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-30-2020, 11:08 AM | #5 | |
10-03-2020, 05:43 AM | #6 | |
Disregard- I found them on amazon. Are these a plug and play replacement? Any other mods needed? Last edited by AllGoNoShow; 10-03-2020 at 06:01 AM. |
10-03-2020, 10:10 AM | #7 |
Old member
N0 mods just take the old bulbs out of the black socket and install.
10-03-2020, 12:23 PM | #8 |
LED dash lights are a nice upgrade, I've done it on a few trucks. But you will also want to consider that your original dimmer switch will no longer work with this upgrade. LED's require very little power, they will operate at the same brightness over a wide range of voltages. If you want to be able to dim your LED dash lights you will need to use a PWM (Pulse Wave Modulation) type dimmer.
One example: https://www.amazon.com/Auto-Meter-91...ews/B000N8GIYG
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-08-2021, 05:13 PM | #9 | |
Here is the link to the bulbs the guy below used. https://www.amazon.com/ENDPAGE-Chips.../dp/B07T6LQVYQ
Figured someone could use it after they spent all that time looking at youtube videos. Quote:
10-03-2020, 04:17 PM | #10 |
We upgraded my son's 69 to led. Simple, just unplug the old and plug in the new. No wiring needed and they are a lot brighter.
10-03-2020, 07:20 PM | #11 |
Old member
These LED lights do dim but not much no where near the normal bulbs but they do dim.
