Removing SM465 with bellhousing; support BBC?
I am gonna try and swap my SM465 with an NV4500 in this next week but I need help figuring out how to support the rear of the engine without a bellhousing there.
Here's my options: Remove trans and leave engine and bellhousing installed: Cannot access top two bell-to-trans bolts when installing NV4500(Using Leons method: http://67-72chevytrucks.com/vboard/s...d.php?t=673588) Remove trans with bellhousing, leave engine: Engine has no rear support. Remove engine and trans completely: I'd like to avoid this at all costs due to several issues(can't move truck, dont want to remove hood yet, nowhere to store engine, etc) Any advice? |
Re: Removing SM465 with bellhousing; support BBC?
I’ve seen a chain used from one frame rail and under the pan up to the other frame rail.
Of course that was many moons ago before small ratchet straps were available. Easy to attach to each rail and tighten with the ratchet. Double up on it to spread the load on the pan. That should keep the rear of your motor supported. |
I’ve always just used a floor jack with a piece of 2x6 . There really isn’t that much weight with the motor mounts still attached .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Mar 2003
Yep, floor jack or a jack stand with a block of wood. It is kinda surprising how balanced the engine is with the mounts and the exhaust holding it up. But they are heavy, so...
ok, cool, sounds like it's not that unconventional do do this process. Thank you.
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I've used a ratchet strap from a bolt in an accessory bolt hole 7/16-20 in the back of the head(s) to the pinch weld lip at the top of the firewall. That way you can raise and lower the truck without worrying about the jack under the motor...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
As others have said, I guess it's not like all of the engines weight is on that lip, but I'm still surprised that lip of sheetmetal can hold that amount of weight.
With that being said, I like that plan the best, not to mention the cab in the truck is trashed already, I could care less if it bends or warps that metal lip. |
#8 | |
So did you grind the rivets off of the crossmember? Is that normal to do when removing trans?
You know I dont recall the trans crossmembers being riveted. Eight grade 8 bolts, two in the top flange and two in the bottom flange on each side. You have to remove a couple of 5/16 bolts that hold the brake line and fuel line clips. Then use a hammer to knock the crossmember to the rear far enough to clear the tail housing of the trans... The frame is factory drilled to locate the crossmember for a 350 or a 400TH.
MY trans crossmember is riveted for my SM465....interesting.
What year and model is the truck?
#13 | |
The Older Generation
I think you guys are talking about 2 different cross members here. The SM465 used a bell housing cross member that is riveted in and the automatics used a rear transmission cross member that is bolted in.... When installing the NV4500 you use the stock bell housing cross member and the NV4500 just hangs off of the back of the bell housing like the SM465. No transmission cross member. LockDoc
#14 | |
Leon, do you know what U joint to use? |
#15 | |
#16 | |
Good deal guys, No problem. As far as the U joint I will have to see if I can find the receipt on it. I can't remember the number. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-02-2023 at 11:43 AM. |
#17 |
My problem with that is my yoke has a special balancer on it so I'd like to keep it. I'll ask the shop doing my driveline if they have any knowledge.
Thanks for the help. |
