06-13-2014, 12:56 PM | #1 |
Do you use lowering spindles with the Porterbuilt front dropmember?
I've been looking at and investigating the Porterbuilt Dropmember system. I almost have all the dough I need to order the full front setup. My question though is, is it suggested to use lowering spindles with this. My plan is to set my '85 2500 rocker panels to the ground on 22x8.5's on the front and 24x10's on the rear.
Thanks G p.s. Do members on the forum get a discount?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
06-13-2014, 01:06 PM | #2 | |
Re: Do you use lowering spindles with the Porterbuilt front dropmember?
06-13-2014, 01:16 PM | #3 |
I don't think that you can get to rocker using a drop member alone. It will get you to frame but you will either need to Z the front or drop the body
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-13-2014, 01:18 PM | #4 |
I am in progress of modifying the frame under the cab area to get body to asphalt.
06-17-2014, 11:17 AM | #5 | |
Square
hope what im trying to say makes sense. here is a picture of one of my old trucks that i went to pinch on and here is one that lays rocker. notice how the bed sags (also, this truck is still badass... im just relaying my personal view)
Squarebody Syndicate |
06-17-2014, 02:37 PM | #6 |
I should rephrase what I'm saying; I am looking to lay pinch. I do like the look of laying out to pinch weld rather than straight rocker.
I dig your old truck. I while back I say a YouTube vid of it and I've followed some thread on here that I believe you got started.
