Pattern check
I think its close. B/L is .007. Good carrier preload. Coast side looks good to me. What ya think on the drive?
David |
![]() Join Date: Mar 2003
Re: Pattern check
I would certainly run with that pattern
![]() ![]() Join Date: May 2015
Re: Pattern check
Yep, what kw said..!!
Re: Pattern check
No AC in the shop, it's been hoooot sitting in the shop pulling and installing that dang carrier. I gave up on it once and drug it to a shop, but they wanted too much to install the gears, gave me so newfound patience.
David |
![]() Join Date: Sep 2014
Re: Pattern check
I like it, good job!
Re: Pattern check
Since we all like pictures, a picture of the pinion gear and my cheater setup. I can't lift that thing in and out by hand anymore.
David |
![]() ![]() Join Date: Jan 2005
Re: Pattern check
What brand is your gearset? The machining of the teeth looks much cleaner than on a Yukon set I bought recently.
Re: Pattern check
USA standard gear. Came in a yukon gear box.
David |
#9 | |
Re: Pattern check
Re: Pattern check
Here's a photo of my Yukon gear. It has burrs, and the machining is generally rough and unrefined looking.
