07-14-2022, 11:26 PM | #1 |
Pattern check
I think its close. B/L is .007. Good carrier preload. Coast side looks good to me. What ya think on the drive?
David |
07-14-2022, 11:52 PM | #2 |
Re: Pattern check
I would certainly run with that pattern
07-15-2022, 12:10 AM | #3 |
Re: Pattern check
Yep, what kw said..!!
07-15-2022, 08:05 AM | #4 |
Re: Pattern check
No AC in the shop, it's been hoooot sitting in the shop pulling and installing that dang carrier. I gave up on it once and drug it to a shop, but they wanted too much to install the gears, gave me so newfound patience.
David |
07-15-2022, 11:06 AM | #5 |
Re: Pattern check
I like it, good job!
07-15-2022, 02:25 PM | #6 |
Re: Pattern check
Since we all like pictures, a picture of the pinion gear and my cheater setup. I can't lift that thing in and out by hand anymore.
David |
07-17-2022, 09:04 PM | #7 |
Re: Pattern check
What brand is your gearset? The machining of the teeth looks much cleaner than on a Yukon set I bought recently.
07-17-2022, 09:52 PM | #8 |
Re: Pattern check
USA standard gear. Came in a yukon gear box.
David |
07-17-2022, 09:54 PM | #9 | |
Re: Pattern check
07-17-2022, 09:59 PM | #10 |
Re: Pattern check
Here's a photo of my Yukon gear. It has burrs, and the machining is generally rough and unrefined looking.
