04-15-2002, 10:19 PM | #1 |
Electrical Question
Last week my under dash and headlight harnesses burnt. I replaced with used ones yesterday. Now I have no headlights, dash lights, or dome light. I replaced the switch and still nothing. I have power in and out of the dimmer switch. Any ideas? Thanks.
------------------ 69 short box 4x4 72 long box 69 Camaro 327 4-speed 71 4x4 suburban, soon to be crew cab short box 87 S-10 V-8 FOR SALE Des Moines, Iowa
67 short 2wd. FOR SALE 69 long box w/72 grill 69 Camaro 327 4-speed Des Moines, Iowa |
04-15-2002, 10:54 PM | #2 |
Back in the sticks
You should have one red hot wire going directly to the headlight switch that is hot straight from the battery. If you don't have that, you won't have nothing. Good luck, Jeff.
------------------ 1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer New project 1995 K1500 Sub(Mommas car) 1989 VW Golf(Beater) Will be the daughters car if she will pay her insurance! Ha!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-16-2002, 08:46 AM | #3 |
Do you have power at the red wire on the switch? Tailights? I assume you do if you have power through the dimmer. If you have power at the green or the tan wire (hi and low beam) at the dimmer then you should have power at the headlights, unless the wires are burnt, because they go straight to the headlights. As for the dome and others, have you got power at the fuse? Hope this helps.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
04-16-2002, 05:55 PM | #4 |
I have power at the switch and the dimmer switch, but not at the headlights. I have taillights and side marker lights. Maybe it didn't make a good conection at the fire wall. I'll check that tomarrow. The dash harness is a 69 and the headlight harness is a 72. That shouldn't make a difference should it?
04-17-2002, 10:36 AM | #5 |
I wouldn't think so, but not positive. Did you hook up the headlight ground wires at each side of the rad. support when you changed the headlight harness?
04-17-2002, 03:25 PM | #6 |
huh?
Make sure all of your grounds are good, and you said the dimmer switch is ok? If you're not sure on that, try running a jumper wire across it, just to check.....
68
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
