Junk Yartist
91 Suburban Issues
So this is mostly going to be a parts truck for my 1970 build, but While I am working on the 70 body, we are driving this truck. I traded my wheels and tires off my 70 for this rig. It is a 1991 V2500 bare bones 4x4. It had a SES light on when I bought it, and a few other problems that were easy to fix. I have a 43 code that is active right now. I reset it and it came back. I checked the knock sensor and it is new, and ohms are within range, so I moved on to the esc... ok... where is the esc! I have a 95 Yukon and it is mounted on the top side of the bracket that the EGR sol. is mounted to. On the 91 there is not even a connector in that location as indicated by "C"
Other questions... I didn't know they started using the round style 3-pin connectors on TPS see "B" thats a yellow "B" if you cant see it I also have a mystery relay on the fire wall see "A" 95 Yukon ESC Also, did all 4x4's have these spacers in the X-member or only HD sprung trucks. |
Re: 91 Suburban Issues
Those spacers are stock, but in the stock location. I've heard about that being done to improve rear driveshaft angle after installing a lift. Usually the crossmember is flush to the frame the the spacers go between the bolt head and the frame on the inside...my 85 3/4ton was that way. Sorry I can't help with the other questions...I've only really worked on diesel burbs.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 Last edited by rcbildr; 03-07-2010 at 01:54 PM. |
Slots go on anything!
The mystery relay is the fuel pump relay. The wire colors are the same as the earlier TPS; I'll be finding out pretty quickly if is is a direct swap. I am putting a 91 engine in a 87 truck. I don't know if there is a seperate ESC module; it may be in the computer. You may also want to check your wiring to the knock sensor also.
1974 Jimmy- 5.3/4L80e/NP241 |
#4 | |
Ironmonger
![]() Join Date: Dec 2004
Junk Yartist
So I looked at a '90 Blazer with a 350/700R-4 and it was in the same location as the '95 Yukon with a 350/NV3500, so maybe it is not separate on 3/4T and 1T models... anyone?
Junk Yartist
Update on where I am at and what issues the truck is having now.
SES code 43- turned out that the computer was the wrong one for the truck. Replaced the computer and had no further issues with this code. I was averaging 10.0mpg and running at 210-220 degrees F- rebuilt TBI unit, installed new o2 sensor, and installed 160deg t-stat. I am now averaging 13.3mpg. With light driving or hwy driving I would run at 160-180 degrees, but city driving or climbing a hill it would climb to 210-215 degrees. I found that the fan clutch was leaking fluid, so I borrowed the '02 fan and new clutch off my 95 Yukon... no change. This concerns me because my Yukon would do the SAME thing and just died about a week ago. I cant loose another engine at this point. Any thoughts? |
Just a thought, but if you're climbing in OD then the tranny is heating up way hot and the factory cooler integrated into the radiator doesn't help.
On my 4x4 we installed a 4 core radiator first, still got kinda hot, so I plumbed in a secondary cooler inline with the factory cooler that is in the radiator . . . now the truck runs much cooler pulling or climbing hills. I installed the cooler coming out of the tranny and then flowing into the factory unit to avoid overcooling in the winter. I thought all along it was my engine, turned out to be the tranny all along that was really overheating.
If it ain't broke, then I haven't fixed it yet! '86 Fiero SE 2M6 (undergoing a Northstar swap) '87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks) '90 3/4t 2wd Suburban (Tow Rig) '94 3/4t 4wd G20 Van (Toasted tranny and rusted) '96 Deville |
#8 | |
There is no such thing as over cooling a automatic!
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
Does it have a fan shroud?
#10 | |
Junk Yartist
Yes, they both did. |
It took me two trannys and several years to finally get it right myself.
The extra cooler really makes a big difference and the gauge is handy too. Both of my Burbs had the external oil cooler from the factory, but neither had an external tranny cooler even though they both have the RPO code for the tow package . . .
#12 | |
Junk Yartist
Junk Yartist
So i was wondering if anyone had any pictures of 73-91 burbs with a factory remote transmission cooler. I have noticed that my tranny likes to downshift and/or run the TC unlocked more than it should. I am going to troubleshoot the TPS and see where that leads me... but I wanted to see if GM offered a remote tranny cooler of any kind for these bodies. Maybe a 91 diesel? I have 2 aftermarket coolers, but I am not a big fan of rubber hoses with worm-drive hose clamps.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
