Old 01-19-2011, 08:36 PM   #1
Mechanic77
Project Pro Touring "Ole Blue"
Well...I guess I should start a build thread. I'm working on my '64 C10 that I'm building as a pro touring style truck. It actually started out as a C20 long bed step side, but when I'm done, it will be a 1/2 ton medium* bed fleet side.
*Instead of the typical 12"/8" chop, I'm going to do a 9"/6" chop
Here it is at it sits now:
Name:  truck as of now1.jpg
I'll start posting pictures of what I have done already and explain it as I go
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 01-19-2011, 08:39 PM   #2
Mechanic77
Re: Project Pro Touring "Ole Blue"
Here is where I started after tear down:
Name:  truck beginning.jpg
Old 01-19-2011, 09:08 PM   #3
shortbed70
shortbed70's Avatar
Hey another kansas guy...Nice rig cant wait to see it come along,but one question? Are you talking choping the top?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-19-2011, 09:12 PM   #4
Mechanic77
Actually no, I was referring to the 12" removed out of the front and 8" removed out of the rear of a long bed to make it a short bed I've always thought that the short beds were just a little too short, so I'm goint to go 9" in the front and 6" in the rear to make it proportional and hopefully look right to me
Old 01-19-2011, 09:15 PM   #5
shortbed70
shortbed70's Avatar
OK I was wondering... What do you do for a living? Nice arms...
Troy
Big Red Dog build
Old 01-19-2011, 09:19 PM   #6
Mechanic77
Well...I'm just a mechanic (over 10 years already ) but I love doing fab work in the evenings and I love the challenge as well. I'm excited about working on this project because it was actually my first car, so I've got a bit of a sentimental attachment to her too
Old 01-19-2011, 09:09 PM   #7
Mechanic77
Here's some pictures of the work on the front suspension
One of the lower arms I fabbed up (I need to modify the ball joint plate and angle it up to keep the ball joint from binding )
Name:  truck lower arm2.jpg
One of the upper arms jigged up, ready to weld
Name:  truck upper arm jigged1.jpg
Mounting the steering box
Name:  truck steering box2.jpg
Front suspension mocked up
Name:  Truck front suspension almost done.jpg
I built the arms with the ball joints moved forward to center the front wheels in the wheel wells and I also set it up with increased caster (6* base) with the option to go +/-2* besides the normal adjustment available. I'm running 2.5" drop spindles with the 1.25" thick rotors and Wilwood D52 calipers (thanks Jon ) The way I mounted the steering box it actually raises the center drag link approximately 0.75" from the stock '84 front geometry, so I'm hoping I can juggle thing around to reduce bumpsteer as much as possible.
Old 09-13-2013, 02:11 PM   #8
jtrichard
Attachment 684964
Attachment 684965
Attachment 684967
Attachment 684968
what size pipe did you use on the frame for the gear? what is your take on this way VS. the kit?
jtrichard is offline   Reply With Quote
Old 09-14-2013, 11:26 AM   #9
Mechanic77
I honestly don't remember.....it takes two different diameters, a larger one for the top part and a smaller one for the lower (to allow for the mounting holes). As far as my take.....I would suggest the kit, it's waaayyy easier
I did mine that way for a couple of reasons....one, I'm a cheap bastard that would rather make something than pay for it .....and two, I didn't like the idea of the steering box being pushed out because it would make the pitman arm and the idler arm not run parallel (probably doesn't make 2 cents worth of difference, but it would bug the crap out of me)
Old 01-19-2011, 09:24 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Subscribing to this one!!!
Keith
Convert to disc brakes.
Old 01-19-2011, 09:33 PM   #11
shortbed70
shortbed70's Avatar
You must have access to some nice tools...Those arms are pretty nice pieces. I used to be a mechanic also but got tired of leaning over working on things so started welding and never looked back. Ill be watching this one.
Troy
Big Red Dog build
Old 01-19-2011, 10:29 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Nice work! I have a question tho...did you weld that steering box to the frame?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-19-2011, 10:38 PM   #13
shortbed70
shortbed70's Avatar
Looks like a pipe notch to me. I thought that too when I first seen it.
Troy
Big Red Dog build
Old 01-19-2011, 10:43 PM   #14
Mechanic77
Beat me to it I'm a slow typer.
Old 01-19-2011, 10:53 PM   #15
Mechanic77
A little more information:
The tires are 275/40ZR17 for the front and 315/35ZR17 for the rear. I'm planning on buying Billet Specialties Street Lites in 17x9.5 and 17x11 to go with those. To go with the Wilwood front brake calipers, I also bought a set for the rear too. I also bought a set of brake rotors (Astro van fronts, thanks Captainfab for the idea )
What the heck, here's a picture of the rearend with brakes on it and a teaser of my watts link setup
Name:  truck rearend with brakes.jpg
Old 01-19-2011, 11:05 PM   #16
protrash64
Resistance is Futile
protrash64's Avatar
Nice work mech77!! Love the mock-up shot; truck looks good and cant wait to see more.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-19-2011, 10:41 PM   #17
Mechanic77
Thanks for all the comments, and no, I didn't weld the steering box to the frame. I used the lower rear bolt hole on the frame and figured the angle the box needed to be and made new holes for the power box. What you see in the picture is the backside of the notch I made to clear the box so I could mount it straight on the frame. I did that instead of buying an adapter plate because I wanted the idler arm and the pitman arm to be parallel when going straight.
As far as having nice equipment goes, I have the basic welder/grinders/etc, but I do have an awesome buddy that works at a metal fabrication shop building industrial equipment. All I have to do is draw something up (measured drawing) and tell him how thick of plate I want and he cuts it on there cnc plasma cutting table . It sure helps make things look so much more professional
I'll post up some pictures of the rear suspension tomorrow, and you can see some more of his work too.
Old 01-19-2011, 11:09 PM   #18
Mechanic77
Thanks, I can't wait to get the cab off so I can cut the frame down and mock it up at the correct wheelbase
Old 01-20-2011, 11:25 PM   #19
Mechanic77
Here is some pictures of the rear suspension almost done
Name:  Truck rear suspension1.jpg
Name:  truck rear suspension2.jpg
And some pictures of the trailiing arm brackets that I'm going to mount up
Name:  truck trailing arm brackets.jpg
I'm not going to mount those brackets up until I get the cab off because I'm going to flip the crossmember to gain some driveshaft clearance when it's aired out
Old 01-20-2011, 11:28 PM   #20
Mechanic77
Here's some better pictures of my watts link setup
Name:  truck watts link1.jpg
Name:  truck watts link2.jpg
I'm thinking I might swap the 1/2" rod ends and links out for some 5/8" ones and I haven't machined the center pivot for the bearings yet.
Old 01-21-2011, 12:50 AM   #21
SCOTI
SCOTI's Avatar
I like it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2011, 01:18 AM   #22
PBFAB.COM
PBFAB.COM's Avatar
Finally... somebody building a watt's link like they are SUPPOSED to be set-up!!!!!
Looks like a cool project!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-05-2011, 04:35 PM   #23
Pop's C-10
Pop's C-10's Avatar
Killer fab
Pop's C-10 is offline   Reply With Quote
Old 03-06-2011, 01:59 AM   #24
shrunken66stroker
shrunken66stroker's Avatar
You've got the sickness as well. I'll keep an eye on this one.
shrunken66stroker is offline   Reply With Quote
Old 03-06-2011, 11:35 AM   #25
Mechanic77
Yeah, I think it's contagious
