09-14-2011, 09:07 AM | #1 |
Isuzu pup
HELP
I was looking for a repair manual for the 94 Isuzu pip I just bought, there doesn't seem to be one !! They run to 93, but someone mentioned that it is the same basically as the Chev S10 ?? I need the routing of the vacuum hoses, some of the lines are broken causing it to run poorly...any help? Thanks |
09-14-2011, 03:26 PM | #2 | |
Semper Fi!!!
Re: Isuzu pup
Brandon... "IT ONLY TAKES EVERYTHING YOU GOT!!" Semper Fi |
09-15-2011, 09:52 PM | #3 |
Re: Isuzu pup
95 was the last year, after they went same as s10, I went to the main library and made copys of what I needed
67 GMC, SWB, 472 Cadillac, Turbo 400, 273 rear |
09-25-2011, 05:17 PM | #4 |
Re: Isuzu pup
I have a 94 PUP the manuals end at 93...I have a problem that I THINK is related to vacuum hookups, it "hunts" about 2-300 rpm up and down at idle...annoying that I can seem to find the problem
I bought a chev manual for the small pick ups of that era but they seem to have different engines...anyone have a vac hose "plan" in pictures? |
09-25-2011, 10:37 PM | #5 |
BAD BOW-Silverado XST
Re: Isuzu pup
You can find great info at www.autozone.com. They wiring and vacuum hose diagrams available.
10-06-2011, 09:24 PM | #6 |
mini truck racer
Re: Isuzu pup
This is the place to check , they where still Isuzu after the Luv for quite a while . Pretty good little trucks .
http://www.IsuzuPup.com
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
