Drop Spindle and Tie Rod Question
I came across a set of drop spindles for my 71 C10. I'm not sure who made them. The only problem with them is the diameter of the hole that holds the outer tie rod. The hole is a little bigger than the tapered tie rod bolt.
Has anyone else had this issue and what can I do to fix it? Is there a shim I could use? Hopefully I'm not the only one who has had this issue. Any help or suggestions would be appreciated. Thanks |
![]() Join Date: Dec 2012
Re: Drop Spindle and Tie Rod Question
The man to ask about this directly would be lolife99, shoot him a PM.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 09-02-2014 at 12:06 PM. |
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Back in the 1980's all you could buy were 73-87 drop spindles. NOW,... you can buy them for all the years of the C10 trucks. They break down by the following years: 60-62 63-70 71-72 73-87 Light duty 1" rotors 73-87 HD 1.25" rotors.
#4 | |
Here is a true statement about spindles: EVERYTHING has to match the YEAR of spindle you are using. That means: Balljoints and outer tie rods. If your truck is a 63-70 I HIGHLY suggest using 63-70 conversion spindles. They can be purchased for $229 almost everywhere. No need to change any steering parts or balljoints.
#5 | |
#6 | |
They could be the Light Duty version or the HD version. 71-72 and 73-87 trucks use the SAME lower ball joint. But the upper balljoint and outer tie rod is different. Since your truck is a 71-72 model,... you could swap the upper ball joint and outer tie rod,... that is,... if they are in fact 73-87 spindles. If they are the light duty version,... you will need new light duty rotors and calipers. Sometimes cheap spindles aren't always a DEAL. Buy a set of 71-72 drop spindles and save yourself alot of headaches.
Thanks Keith. Your fast.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
Thanks for the correction Keith, I went back and edited my 1st post so their isn't any false info on here.
Everything fit perfect on these spindles except the outer tie rod. the bigger calipers and rotors all fit great. I may just need the HD outter tie rods.
Problem solved. Used 73-87 outer tie rods
if you use a 73-87 ball joints and outer tie rod to fit the spindle will it fit the fit the 63-70 center link correctly
#12 | |
This also requires a conversion tie rod sleeve that adapts a 5/8” tie rod (63-70) to the 11/16” tie rod (73-87).
