08-28-2015, 11:32 AM | #1 |
Upholstery issue
This seemed like the only fitting forum to post this. If it's in the wrong spot, please move it to the correct one, mods.
I have put a lot of time into my console (way more than I imagined). Anyway, I am stuck and I am in the final stage. I have the the inside and outside upholstered (pics attached). I tried wrapping all the way around with 1 piece of vinyl, but it wasn't working out where the sub was. I could not get it clean no matter how many relief cuts I used. I decided to cut and glue the inside and outside pieces separately, and now I have the edges to finish. I tried to use sprinkler line, which kind of works but it's got a natural bend and it kinks when I put it on, which you can really see in the second picture. Heating it only does so much. There has to be a product available that will suit my needs, I just don't know what it is. Any help is appreciated. Thank you in advance. |
08-28-2015, 12:15 PM | #2 |
Re: Upholstery issue
I use door edge trim (comes in about 2' strips at AutoZone or wherever) a lot for that type stuff, but that's probably not wide enough. I usually just stumble around Lowe's when I'm trying to find something that will work.
What about some vacuum line split down the middle?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
08-28-2015, 04:35 PM | #3 | |
08-29-2015, 07:08 PM | #4 |
Console does look nice. Good luck with the idea.
We could use an interior forum . |
08-29-2015, 07:26 PM | #5 |
09-01-2015, 01:20 PM | #6 |
I second that We could use an interior forum
, headliners, door panels trim pieces all VOODOO that can leave you frustrated or Broke paying big bucks to a pro shop !
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD Last edited by 48 GMC BURB; 09-01-2015 at 01:22 PM. Reason: added info |
09-01-2015, 01:30 PM | #7 |
meowMEOWmeowMEOW
FWIW the "right" way to do that would be to cut each piece with a 1/4-1/2" overlap, then roll and double-stitch them, putting the seam at the apex of the bend. If you look at how the bespoke builders run tweed or leather interiors, all "hard" edges usually have a sewn seam.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-01-2015, 01:34 PM | #8 | |
09-02-2015, 10:35 AM | #9 |
If you do want to continue doing this kinda stuff,you can PU old sewing machines for next to nothing.I picked up 3 for nothing,ordinary home machines and I,ve reupholstered the back seat of my old car and it turned out pretty good,now I,m doing the truck seat.I wish there was some sorta interior forum
Tags |
console, upholster, upholstery |
