Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 04-02-2021, 10:36 AM   #1
72tutone
CPP Engine Mounts
Part number - Classic Performance 6372MP-SM,
Used for mock up. No miles on them. Motor didnt sit well for my liking.
Summit price -159.99
Selling for 90+ shipping.
72tutone is offline   Reply With Quote
Old 04-06-2021, 07:34 AM   #2
notsolo
notsolo's Avatar
Re: CPP Engine Mounts
Shipping to 21863 Thanks, Ed
notsolo is offline   Reply With Quote
Old 04-06-2021, 08:10 AM   #3
72tutone
I will check asap today and let you know.
Old 04-06-2021, 09:37 AM   #4
notsolo
notsolo's Avatar
I'm trying to reuse the OEM A/C compressor, do you think these will work?
Old 04-06-2021, 10:05 AM   #5
72tutone
The engine perches installed onto the frame do not dictate this. Its more so the mounts installed onto the engine. Some are fixed, some slide. The slide ones are what you want. That is where the adjustability comes in.
The CPP slider mounts I also have for sale are supposed to allow a low mount AC to be installed. From the summit link -
https://www.summitracing.com/parts/c...yABEgLMcPD_BwE
Notes:
Adjustable from 2.25 to 3.75 in. forward for engines with low mounted A/C compressor.
I never tried installing mine though. But the slides worked well. Worse case scenario I've also seen an aftermarket bracket that hugs the engine real tight to low mount an AC compressor.
Old 04-06-2021, 10:30 AM   #6
dec010974
dec010974's Avatar
Not to ruin a sale, but to run the stock A/C compressor, with the stock bracket, in the stock location, on any LS motor, I used stock components. I did this by using the clam shell, frame and motor mounts from a 1973-1987 c10, Square body with adjustable, adapter plates. Also, the Stock, A/C compressor bracket will have to be cut/modified to clear the clam shell motor mounts. Lastly, you will use the stock LS, A/C compressor. Good Luck.
dec010974 is offline   Reply With Quote
