Old 01-09-2022, 08:21 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Drum to Disc, Changed Track Width
So Eons ago when I changed from Stock Drums to Disc Brakes on the front of my 70 I recall it widening my track width. It was at least 30 years ago I used ECE 2 1/2 drop spindles to change over to disc.
On to present day; I just put a set of 20’s on with 245/45 on the front for more side wall. I had to bring the front up 1/4 “ (easy to do with coil overs) so not to rub the outside of the tire.
Now I see CPP makes a spindle that’s supposed to bring the track width back to the original drum brake spec or some where near depending on who you talk to. I even got two different answers from CPP, LOL. Anyway I have a set of theses spindles that I’m going to install as soon as I get the caliper brackets. This should give me all the tire clearance I need. I’ll keep you posted as I go along in the next couple weeks
If anybody else has already done this Please let me know how it turned out for you. Apparently it’s different for different years and now that I have all QA1 Control arms who knows ???????? Going to give it a shot
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-09-2022, 11:08 PM   #2
tallic68
Active Member
Re: Drum to Disc, Changed Track Width
Would love to hear you results patiently waiting your thoughts.
tallic68 is offline   Reply With Quote
Old 01-10-2022, 12:16 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Besides the spindle a LOT of the track width changes with the angle of the the lower control arms.
The flatter they are, the wider the track width.
So a shorter coil spring will also widen the track width because the lower control arm swings up in an arc.
Keith
Convert to disc brakes.
Old 01-10-2022, 12:22 AM   #4
1970 CST Short Wide
Senior Moment
Ya, I’ve been trying to get my head around this. Now I don’t have a coil spring in the traditional since, I have coil over shocks. I’ll only be into this $325 and if it works it will be well worth it. If not, live and learn
Pittsburg Ca
94565
Old 01-10-2022, 02:04 AM   #5
lolife99
lolife99's Avatar
Many people have spent a ton of money trying to make wheels fit.
When in reality, you should install the suspension you want and buy wheels that fit.
Just my opinion.
Too many wheel companies are building the wrong offset wheels for their “off the shelf” affordable wheels.
Finally companies like Billet Specials and StreetMachinery have come up with the Speedway and Magneto wheels, with usable backspace numbers,… in a low price alternative to billet wheels.
Keith
Old 01-10-2022, 09:11 AM   #6
SCOTI
SCOTI's Avatar
Are you referring to their 'Modular' spindle?
Disc brake spindles = wider track width vs. drum brake spindles.
CPP makes a 'modular' drop spindle that is supposed to equal the drum brake spindle track width. The modular spindle requires the 'add-on' caliper bracket so you can select the appropriate bracket depending on what brake set-up you choose (stock caliper or aftermarket).
Standard disc brake spindles w/aftermarket brake hubs can increase track width depending on the hubs. So the modular spindle w/aftermarket big-brakes may possibly wind up the same track width wise as a standard disc set-up depending on the hub + rotor-hat combo (or only slightly narrower). I think one would have to verify w/the specific brake kit manufacture to know for sure what impact the brake set-up might have to track width.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2022, 03:05 PM   #7
1970 CST Short Wide
Senior Moment
Yes I have the New “Modular” spindles. A lot of what I’ve read along with talking to CPP tech (2 different answers on how much it should move )I’m hoping it works
I agree correct back spacing should be bought after the suspension is done. That ones my Bad , my math sucks.
Pittsburg Ca
94565
Old 01-10-2022, 04:53 PM   #8
SCOTI
SCOTI's Avatar
I just wanted to post that info because there are people out there that think even w/the modular spindles the track width won't change. It doesn't if using OE discs. Once you go aftermarket (bigger brakes) the hub & rotor dimensions can add to the width over what it is w/stock discs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-10-2022, 09:07 PM   #9
1970 CST Short Wide
Senior Moment
I just wanted to post that info because there are people out there that think even w/the modular spindles the track width won't change. I doesn't if using OE discs. Once you go aftermarket (bigger brakes) the hub & rotor dimensions can add to the width over what it is w/stock discs.
CPP told me it only works with 1 1/4 OE discs and that it will move in ~3/8 - 1/2 “. I’m willing to do the work and find out for sure we’ll see. Just waiting on the Brackets
Pittsburg Ca
94565
Old 01-10-2022, 10:33 PM   #10
SCOTI
SCOTI's Avatar
Yep. They dont work w/the Lt.Duty truck brakes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-13-2022, 01:42 AM   #11
1970 CST Short Wide
Senior Moment
Parts should be here next week. Called for ETA and they said would ship by Monday
Then we’ll put this ? To rest. Stay tuned
Pittsburg Ca
94565
Old 01-17-2022, 08:26 PM   #12
1970 CST Short Wide
Senior Moment
Ok so here is the answer. I put CPP module spindles on which moved my wheels IN ~ 1 inch
From where my old ECE spindles were.I measured both from Frame to top of rotor. The only thing I don’t like is there is no mount for dust shield
Both sets are 2 1/2 drop. Now I can reset ride height and have it aligned
Pittsburg Ca
94565
Old 01-17-2022, 10:06 PM   #13
lolife99
lolife99's Avatar
I thought the Modular spindle from CPP were only a 2” drop?
Thanks for the measurement and info.
Keith
Old 01-18-2022, 12:20 AM   #14
1970 CST Short Wide
Senior Moment
You know I think your right. I rechecked before and after height and ya I’m setting a bit higher so I’m IN and UP. The Up I can adjust the IN helps
Pittsburg Ca
94565
Old 01-18-2022, 08:53 AM   #15
SCOTI
SCOTI's Avatar
http://www.cpptalk.com/ShopTalkSite/st52.html
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2022, 01:41 PM   #16
lolife99
lolife99's Avatar
So now it’s a 2-1/2” drop spindle?
I can’t keep up.
Keith
Old 01-19-2022, 01:06 AM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
It might have been more than that, if you're going by your 15" and 16" measurements to the rotors face... Wheels don't mount to the rotor face, it looks like the mounting flange is further back too. It looks more like you went from 16-7/8" to 15-5/8, maybe 3/4, hard to tell with angle. So maybe 1-1/8 to 1/1/4 per side? That's a big gain! I had to buy a set of 7" wheels for the front of my truck because my old 8" wheels rubbed bad with the drop.
I agree with the "off the shelf fits all" comment. I have a 68 firebird and bought a set of the 17" pontiac rally II wheels. Look killer. However, they really need to be sucked in 1/2" in the rear (fixable with rolling/cutting the fender lip) but the front really needs to go in 3/4-1" per side if you want to drop the nose of the car any at all. They're "work" with stock height springs, but barely and you have to run a small tire. These are claimed to "fit" all 1st and 2nd gens. They definitely fit the 69s and 2nd gens better (they're a couple inches wider). It's a shame because they look so great, but really, the offset is all wrong to fit 67/68s.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-19-2022, 01:43 AM   #18
1970 CST Short Wide
Senior Moment
As I said ~ 1”. I knew the measurements weren’t very accurate, I measured from a convenient spot I could go back to. The whole idea was to see if it really worked as I kept getting conflicting answers.
Pittsburg Ca
94565
