03-20-2023, 07:30 PM | #1 |
proportioning valve has 2 front outlets?
My new disc/disc proportioning valve has 2 front brake outlets. The one I took off only has 1 and uses a splitter on the cross member. Is there any reason I can't run the way it was set up and plug one of those outlets? Or do I need to use both outlets on the proportioning valve because it has two?
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
03-20-2023, 08:04 PM | #2 |
Re: proportioning valve has 2 front outlets?
My disc/drum combination valve came with a plug in the upper outlet, and that's the way I installed it. I'm assuming this arrangement would also be fine for your disc/disc setup.
https://www.summitracing.com/parts/clp-pvks-b1 |
03-20-2023, 09:03 PM | #3 | |
I'm really not that smart. LOL.
03-20-2023, 11:36 PM | #4 |
Instructions?...We don't need no stinking instructions! Lol!
03-21-2023, 08:01 AM | #5 |
That has always been my philosophy, but when it goes wrong and I do read them and the answer is obvious I really feel stupid. "Oh sure that would work!" LOL
03-21-2023, 01:04 PM | #6 |
So I am a few months away from getting the cab back on and connecting the brake lines.
My question is do most of you use a 'T' for the front brakes or use both ports for the front brakes? |
03-21-2023, 01:53 PM | #7 |
Since my 72 "stock" lines are "T", I chose to just leave them that way and use the plug on other front port of PV.
My 67 (Camaro) with separate lines, I use both. If you are making your own lines, using both is not a problem. |
