Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 04-03-2023, 06:07 PM   #1
MDPotter
MDPotter's Avatar
1978 Chevy Scottsdale K20 Camper Special
1978 Chevy K20 Camper Special
350/TH400/NP203
Odometer shows 19,xxx but true mileage unknown.
Dana 44 front/Full float 14 bolt rear
New wheels and tires
Runs and shifts well
Just did a tuneup (plugs, wires, intake gasket, set timing, replaced fuel pump)
Front brakes rebuilt-rotors, pads, calipers, hoses, wheel bearings
New front driveshaft
New interior (dash pad, gauge bezel, bluetooth radio, front & rear speakers, flooring, seat foam & cover, door panels, heater core, headlight switch, turn signal switch, instrument cluster circuit board)
New window regulators, mirrors, grille, all new bulbs and lenses
Very little body rust. Some bubbling at wheel openings and some rust under battery tray but is a solid truck.
This truck is geared pretty low - probably 4.10 in the rear and 55 MPH is about the max.
Fuel gauge does not work - probably needs new sending units. Could also use carb adjustment or rebuild.
Asking $7,500. Located in Grand Junction, CO. Can provide more photos upon request.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 08-14-2023, 02:21 PM   #2
COCONUTS
COCONUTS's Avatar
Re: 1978 Chevy Scottsdale K20 Camper Special
Good afternoon,
Is this truck still available?
Greg in Missouri
COCONUTS is offline   Reply With Quote
Old 08-14-2023, 03:09 PM   #3
MDPotter
MDPotter's Avatar
Originally Posted by COCONUTS View Post
Good afternoon,
Greg in Missouri
Yes it is. Just replaced both sending units and driver side tank. Needs a new speedometer cable.
