Old 06-25-2020, 12:16 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
QA1 Coil Over System
Has anybody installed the QA1 Coil Overs in there 67-72. If so ,Did you have any problems and most of all How do you like it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 06-25-2020, 12:39 PM   #2
SIXTY9
Re: QA1 Coil Over System
Yes I installed that system on my 69. I really liked the way it installed and I also put the rear sway bar on. I also installed the front system also with the sway bar. I am still in the process of building my truck again, so I have not been able to drive it yet. It installs very easy. The rivets are not to bad to remove.
Wally
SIXTY9 is offline   Reply With Quote
Old 06-25-2020, 03:20 PM   #3
1970 CST Short Wide
Senior Moment
Wally
Thanks Wally That’s good to hear. My only worry is my Ford 9” housing being bigger than the 12 bolt and I have a Boyd’s tank in the rear which they say shouldn’t be a problem.
Would you have any pics of the install?
Steve
Pittsburg Ca
94565
Old 06-25-2020, 05:16 PM   #4
SIXTY9
I am using a 69 Camaro tank and have no clearance problems. The only thing I have not worked out is the exhaust. And I am still using my 12 bolt out of a 72.
I can’t get the pictures right. And I don’t have the gas tank back in yet.
Old 06-25-2020, 09:47 PM   #5
1970 CST Short Wide
Senior Moment
Thanks for the pics. ? How close are the bars to the rear end
Pittsburg Ca
94565
Old 06-26-2020, 05:52 AM   #6
SIXTY9
Here is two more pictures and there is 1 3/4” between the bar and rear end cover. Also I bought my kits thru a JEGS they had the best price.
Old 06-26-2020, 09:05 PM   #7
1970 CST Short Wide
Senior Moment
Thanks for the pics it’s exactly what I needed to see. I have a Friend that’s a dealer for QA so I’m getting a killer deal. The rear using MY arms is $805. I like the kit that allows pinion angle adjustments but I have Early Classic Enterprise solid arms and a Ford 9 inch so I’ve addressed the Pinion angel issue a long time ago. The little I can see looks like your doing a killer build. Are you doing the front with QA also? I may look into the rear sway bar too
Thanks for all the info I really appreciate it
Steve
Pittsburg Ca
94565
Old 06-26-2020, 09:36 PM   #8
SIXTY9
Yes I have already installed the front system with the sway bar also. Thanks for the complement. I have just been taking my time on it and enjoying the process. This time I am doing the thing to enjoy it when I retire. Here are a few pictures of the front. It was not to bad to do, only the 4" hole in the upper mount.
Old 06-26-2020, 09:45 PM   #9
SIXTY9
Here is some better pictures. The first one is the 4" hole I was talking about.
Old 06-27-2020, 12:12 AM   #10
Southpaw69
I'm thinking about this same setup. Hope someone will chime in with how it rides and if it's worth the cost. The adjustability is the part that stands out to me.
Southpaw69 is offline   Reply With Quote
Old 06-27-2020, 02:37 PM   #11
1970 CST Short Wide
Senior Moment
My kit should be here next week, just rears, I’ll let you know as soon as I’m done
Pittsburg Ca
94565
Old 06-27-2020, 02:40 PM   #12
1970 CST Short Wide
Senior Moment
Very nice. I’d love to do the front also but it’s pricey. I’m already retired and enjoying my truck
Pittsburg Ca
94565
Old 06-27-2020, 03:17 PM   #13
SIXTY9
Hey that is one beauty, I know what you mean about the price. I had to do a lot of hard thinking and decided that I was not going to spend a bunch of money on a new truck. The first one was before and the second one as it sits now. Maybe someone can turn the pictures.
Old 06-27-2020, 06:24 PM   #14
1970 CST Short Wide
Senior Moment
VERY Nice
Pittsburg Ca
94565
Old 10-15-2020, 08:49 PM   #15
Speedracer39
Speedracer39's Avatar
I’m interested in buying the same rear coil over kit that you are using but I have a c notch kit that’s been on for a while and I wondering if you have a picture of the drivers side coil over mount so I can get a idea if the 2 will fit side by side?
Speedracer39 is offline   Reply With Quote
Old 10-15-2020, 09:23 PM   #16
geunther
geunther's Avatar
Pics turned
geunther is offline   Reply With Quote
Old 10-16-2020, 05:11 AM   #17
SIXTY9
geunther, Thanks for turning the pictures.
Speedracer39 Here is the pictures, hope they help.
Old 10-16-2020, 10:55 AM   #18
Speedracer39
The pictures are perfect, Thanks a bunch
Old 10-16-2020, 08:10 PM   #19
SIXTY9
No Problem glad they helped.
Old 10-18-2020, 05:05 PM   #20
69GMC2004
Active Member
I had to modify my c-notch to mount the rear coil brackets to the frame. I welded in the c-notch instead of bolting it in. QA1 will not sell the upper coil mount with built in c-notch alone and you can only get the QA1 c-notch if you buy the kit that include their arms (which was nearly an extra $2000 Canadian when I purchased them). It does work, but I can almost promise you that you will need to modify your notches.
I can send you some pictures if needed too.
69GMC2004 is offline   Reply With Quote
Old 10-18-2020, 06:05 PM   #21
SIXTY9
69GMC2004,
Have you ran your exhaust over the rear end yet? If you have can you please post some pictures ?
Thanks,
Wally
Old 10-18-2020, 06:58 PM   #22
bigmac73
bigmac73's Avatar
Wally,
not trying to hijack a thread . but i am interested on where you got your steering shaft and joints from??
Mike
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-18-2020, 07:32 PM   #23
69GMC2004
Active Member
69GMC2004,
Thanks,
Wally
I haven’t done the exhaust yet but I had planned to exit before the rear wheels.
Old 10-19-2020, 04:29 AM   #24
SIXTY9
bigmac73,
Here is the list and part numbers. I got them thru JEGS.
UPPER
Steel Double D U-Joint
1" DD X 13/16" - 36 Spline
153-015240
LOWER
3/4" - 36 Spline X 3/4" DD
153-013449
Telescoping Double D Steering Shaft
3/4" X DD X 1" DD X 26" Long
555-607102
Wally
Old 10-19-2020, 10:50 AM   #25
Speedracer39
After looking at pics I’m thinking I will need to trim part of my c notch for the coil over mount to fit properly but shouldn’t be much of a problem . Here is a pick of my c notch
