VIN Help
Is this a legit VIN? I looked at the decoder on here but it doesn't completely make sense to me.
KE149 J 831993 The seller is claiming it to be a 1969 K20. Thanks for any help. Last edited by Adam Moyers; 02-22-2021 at 09:29 PM. |
![]() Join Date: Oct 2009
Re: VIN Help
VIN is for a 69 K10 built in Janesville, WI. Does the truck have 6 lug or 8 lug wheels? If 8, it's either had axle swaps or a K10 cab swapped onto a K20 chassis.
Re: VIN Help
It's 8 lug. It's had a 68 front clip put on.
Here are the details listed. No idea what a "Double C Frame" is? Kinda worried about that. Rebuilt 357 c.I. Sbc Tci th400 Np 205 steel case transfer case Dana 44 front end Eaton rear end 40” pro comp extreme mt2s moto metal 962s 8 lug 3/4 ton axles Warn lock outs 4 wheel disc brakes Double c frame Heavy duty spring suspension lift New custom made harness |
Re: VIN Help
that's a very customized truck. "new custom made harness" would be enough to scare me away
![]() Join Date: Feb 2002
Re: VIN Help
Look for a partial VIN on the frame above the steering gear. It will be just 9J831993.
No KE24.
#6 | |
The Older Generation
Re: VIN Help
Not sure why you would be that afraid of a custom made harness without actually seeing it. I have seen some awesome custom made harnesses in my day. Well, compared to what I build any way.... ![]() I wouldn't pass judgement on any part of that truck, as far as the build, without looking at it. Yes, it may have some concerns as far as what has been changed on it but by the list it looks like he has been pretty honest on that. I would definitely be asking some questions but it looks like a nice truck. LockDoc
All about them K’s
![]() Join Date: Jun 2014
Re: VIN Help
I like it. 40’s are way up there though, check the frame around the steering box for cracks. Big tires put lots of stress on that area of the frame. Remember the only difference between the Longbed K10 and K20 year for year is the springs and axles. They share the same frame. If the frame and cab share the same partial vin than you know it’s had axles swapped, also in a 69 pickup you would have still gotten the t221 rockwell transfer case. So not only has the transmission been swapped(no th400 4x4’s 67-72) but the transfer case as well. Really not a major deal unless your after an original truck.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
