One for the Book On Tilt Install
Just Install Tilt In my 71. Anyone who is doing this upgrade
using a Tilt from a 70's to early 80's van. Make sure you have the Back-up/neutral switch when you remove the column from the Van. I pulled one from a 74 GMC STX. and the switch was mounted on the side of the tranny(Get all the wiring and the linkage to just in case you need it From the tranny). That's if your have a T350 tranny.It will save you another trip to the bone yard. Also a good Web site Is Shane's 67-72 Chevy Page.
71 C10 LWB With Edelbrock 7101& 1406 Carb Accel HEI Blue Print Accel 8.8 Wires Soon to have possi & 186 Camel hump heads Dropped 2-1/2F&4R Dynomax Headers Duals Flowtech Aftburners Tonneau Cover Frm 89 F150 79 Monte C |
i ran into the same problem
i just swapped the old switch over after some fabrication.
i cut a slot in the column, then i bent the piece that came out to match the arm that operates the switch, next i attached the bent piece to the gear selector shaft, and finally i attached the switch to the outer column then i was done. had to do this b/c the person who pulled the column didn't get the switch of the tranny.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
Tilt Install
Where were you when I need you yesterday. I had to go back to the Bone yard and pull the switch off the Van. that's a 50 mile round trip each time. Lesson learned
outside...
... building a garage to do more work on my truck.
