Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 02-24-2006, 08:26 PM   #1
truckdude239
truckdude239's Avatar
turn singal switch info need
was wondering if any could tell me how to install a turn signal switch ina 71 c-10 i know its not hard just any help i thank you now
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
truckdude239 is offline
Old 02-24-2006, 10:32 PM   #2
matthufham
Re: turn singal switch info need
1. remove steering wheel with a steering wheel puller
2. unscrew it with a phillips, just 1 screw
matthufham is offline
Old 02-24-2006, 11:03 PM   #3
68SUB
After you remove the steering wheel you have one screw in the turn lever, one in the flasher button, and three in the switch. Unplug wires and feed up through the bowl. GOOD LUCK!!! Gary from Charlotte
68SUB is offline
Old 02-24-2006, 11:11 PM   #4
truckdude239
okay anyone knwo a good place to get a compelete turn switch advance auto wants 27 but the picture on there site dont have the hazard button and i need one of them too http://www.partsamerica.com/ProductD...pe=832&ptset=A
or i can get one from mane truck parts for 34.95 with it what do yal think? http://www.manestruckparts.com/store...&Category_ID=8
David fuller
2000 Tahoe 5.3l 378
Old 02-25-2006, 12:00 PM   #5
70c10
67-72 Addict!
70c10's Avatar
I got the whole kit from my local Chevy dealer. Don't forget to disconnect battery before removing switch because you have to press the hazard button in to gain clearance in order to angle it up and out.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline
Old 02-25-2006, 03:57 PM   #6
BubbaGreen
many vendors sell this item...it may still even be available from GM.
A good site to check out is: www.wiringharness.com
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline
Old 02-26-2006, 01:48 AM   #7
truckdude239
ummm i dont have a hazard button anymore lol
David fuller
2000 Tahoe 5.3l 378
Closed Thread
