Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 03-02-2006, 05:42 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Tips for spring removal
Getting ready to remove my springs this weekend to cut them. Anyone have any comments.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline
Old 03-02-2006, 05:51 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Any tips for spring removal?
I cut 1.25 coils and got about 2 3/4" drop. After you cut the first coil use it as a template with a sharpie on the other one to be exact for the cut.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline
Old 03-02-2006, 05:53 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no need for a compressor.
Support the truck by the frame
place floor jack under lower a arm and lightly lift... just enough to place a small load on the spring.
Disconnect lower ball joint
slowly lower jack. The spring will simply fall out. It will not be under pressure.
Longhorn Man is offline
Old 03-02-2006, 05:56 PM   #4
70c10
67-72 Addict!
70c10's Avatar
LonghornMan is correct. Be careful when lowering the jack that you don't pull on the brake line too hard.
Jim
70c10 is offline
Old 03-02-2006, 06:09 PM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
Sweet
Andy
Zumo is offline
Old 03-02-2006, 07:50 PM   #6
hotrodhomi
hotrodhomi's Avatar
Why don't you buy new springs. They are cheap. I've had both and I would not recomend cut springs.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline
Old 03-02-2006, 08:48 PM   #7
glberen
what do you cut the springs with?
glberen is offline
Old 03-02-2006, 08:49 PM   #8
70c10
67-72 Addict!
70c10's Avatar
A 4" fiber disc.
Jim
70c10 is offline
Old 03-02-2006, 08:56 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm opposite of hotrodhomi, I've had springs from Belltech, Eibach, Ground Force, and Early Classic. After all that, I've always been just as happy with cutting stock springs. One coil gets 3 inch drop without riding any worse than custom wound lowering springs.
Zumo, there are several ways to separate the lower ball joint. Some ways tend to damage the boot, some don't. I do the "loosen the nut way off and smack the spindle hard with a hammer method". It's never failed to work and doesn't damage the grease boot or anything else like a pickle fork will.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline
Old 03-02-2006, 10:50 PM   #10
Longhorn Man
One man's budget part... is another man's truck budget. Not everyone has 200 bucks to throw at the springs, and many wouldn't call them cheap.
Old 03-03-2006, 10:15 AM   #11
Joe67
67 is sold
I guess I'll be the one who recommends using a spring compressor on the front springs.
I know quite a few people don't, but if you are not careful, removing them without one can cause serious injury...
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 03-03-2006, 10:34 AM   #12
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you dont want to risk damaging you ball joints, you can remove the two U bolts that hold the lower control arm to the cross member.Just make sure you put the jack on the cross bar or on a solid place on the lower arm because there will be more flexibility with it only being held by the lower ball joint.
sneakysnake is offline
Old 03-03-2006, 12:25 PM   #13
LONGHAIR
I am totally with TxFirefighter on this one, the hammer method works very well. Just remember to leave the nut on, loosened by several threads. If you totally remove the nut the spindle/upper a-arm assembly can jump off of the ball-joint stud. This can result in damage to the boot too.
Of course every TV show that I have ever seen uses the pickle fork method, either with a hammer or air-chisel. This is fine if you are replacing the ball-joint.....but not for general dis-assembly and re-assembly of the original parts. This method may also be perfered in the case of custom painted or plated/powder-coated parts.......I think you can still buy the grease boots seperate from the ball-joints, though it has been many years since I tried.
There should not be any tension on the spring when you lower the a-arm, it should drop far enough for the spring to just fall/roll out........be prepared and watch you feet. Newer trucks (or those with new/tight bushings) may require you to pry down a bit to get the spring to drop out....S-10s usually require this too.
The new (shortened) springs got back in just as easily. Just set them in place in the lower pocket and raise the jack. As the spring contacts the upper pocket give it a tug/jiggle to be sure that it seats properly and continue to raise it up to meet the spindle. If it is not centered you will hear/feel a nasty snap when it does pop in under tension.
After you are done installing the spring it is a good idea to make sure that there is some tension on the spring when the suspension is at full droop. (resting on the bump-stop) Execssively shortened springs will be loose especially if the bump-stop is worn or missing.
LONGHAIR is offline
Old 04-08-2006, 11:29 PM   #14
Zumo
Hot Rods For Life
Zumo's Avatar
where on the spindle do I hit? Won't I damage the threads?
Andy
Zumo is offline
Old 04-09-2006, 12:23 AM   #15
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Be sure you hit the spindle, not the ball joint stem!!!!
It may be easier if you have both wheels off the ground, then you can turn the wheels completely to one side to get a bigger area to swing at. Hit the spindle right where the ball joint stem goes through it. Thats another good reason for leaving the nut on, just in case the hammer glances off of the spindle and hits it, it will protect the threads.
Get a BFG, not a little wimpy ball peen. Should only take a good smack or two.
BTW, I used to work in alignment shops when I was wrenching, and never used a compressor or anything else when removing coils. Struts are a different story, but just lower the arm slowly and nothing will happen.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 04-09-2006, 01:06 AM   #16
Zumo
Hot Rods For Life
Zumo's Avatar
SHould I disconnect the shock and sway bar from the lower spindle as well?
Andy
Zumo is offline
Old 04-09-2006, 02:01 AM   #17
glock35ipsc
Yes.
Bob
Old 04-09-2006, 09:31 AM   #18
Zumo
Hot Rods For Life
Zumo's Avatar
Cool.
Andy
Zumo is offline
Old 04-09-2006, 09:57 AM   #19
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I've got a brass pin that I use when hammering on anything on my truck. It came out of a U-joint for a big rig. Since the brass is softer than steel, I don't have to worry about damaging the steel.
Ft. Worth Gear and Axle have them, and most likely other places that work on big drive shafts will have them as well.
Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline
Old 04-09-2006, 09:59 AM   #20
Rokcrln
Rokcrln's Avatar
Yes the nut, Hammer, smack works great! I have been doing it this way for about 20yrs now with out fail or injury. Just did it yesterday on "Project Trazer" (blazer section) so we can detail the frame and install a "C" notch kit.Zumo do you plan on just cutting the front springs or also the rear? I think the rear will give you some trouble trying to clamp them back inplace. May be someone has a tip on this as well for you since we have only be talking acout the fronts so far! Good luck and do not for get the brfore and after pics!!!
Kevin
LFD Inc.
Rokcrln is offline
Old 04-09-2006, 12:15 PM   #21
Longhorn Man
you can't (at least shouldn't) cut the rear springs they are tapered or pigtailed.
Closed Thread
