Old 12-25-2007, 05:48 PM   #1
Evans
Evans's Avatar
Different projects last couple of months ...
I worked for my engine builder ( K-Star Automotive ) for the past couple months to help pay for my new engine build-up so that took up most of my free time but I did start a few other things and now that the motor is home I can get back to putting time in on the truck ... so here's a few pics of things ....
The new motor ... 355 sbc , 9.6:1 compression , ProComp alum. heads with some work done , KB pistons , Victor Jr. intake , Holley 700 DP , Comp Cams 280H cam , Crane Cams 1.6 roller rockers
Fuel system / Battery move ... Summit fuel cell along with Summit complete fuel system up to the carb (not complete yet), Battery moved to bed (not wired up yet )
Electric fan upgrade ... Dodge Ram electric fan fitted into factory fan shroud
Evans is offline   Reply With Quote
Old 12-26-2007, 04:53 AM   #2
mike nutt
69fatmotor
mike nutt's Avatar
Re: Different projects last couple of months ...
looking good evan ! sounds like a stout little motor. keep up the good work !
mike nutt is offline   Reply With Quote
Old 12-27-2007, 06:24 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like you got a nice project rolling there. I had one of those fuel cells in the bed of my truck quite a few years ago and after the cap sat in the sun for a few years it was a real p.i.t.a. to get on and off.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-27-2007, 12:11 PM   #4
Evans
Evans's Avatar
Yeah , it'll be gone when I get the truck running and can afford an aluminum RCI set-up
Old 01-02-2008, 03:39 AM   #5
Jim_PA
What happened to the other engine?
Jim_PA is offline   Reply With Quote
