Old 12-12-2008, 12:43 AM   #326
jwart
Re: My 1965 build thread
cp has supposed to have rectified mismatched calipers on my powerbrake conv.kit since june keep telling me they will take care of it yeh sure! nice work bud i am driving/ building 65 fleet & working on 54 . we got some of the same taste. keep up the tread. looks great!! jw
jwart is offline   Reply With Quote
Old 12-12-2008, 12:49 AM   #327
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by sdailey View Post
Looking good Alan.
Gotta love progress
If I can quit chasing parts and just work I'd be happier. I was chasing more parts today. I picked up gasket kit, reverse flow water pump, fuel pump, sending units for water and oil, front wheel bearing seals and motor mounts. Tommorrow I'm going to a guy that has some extra small block parts to see what I can find.
Originally Posted by joe231 View Post
Alan, i'm gonna start calling you Super Resto-Man!
Remember I was once labled "Captain obvious". How did I aquire the new title?
Originally Posted by kizer View Post
Man we need to figure out how to cut you off from the Miatas. I think he's obcessed with them.
Hey truck progress looks awesome
At least with this Miata I'm making some $$ to support my truck habit. Thanks for the compliment.
OK here is the last pic of the gauges they are finished except for wiring.
Here's the fuse panel
I'm trying to decide which way to mount it.
Verticle- wires connect on the left
Horizontial- wires connect on top
Alan's Classic is offline   Reply With Quote
Old 12-12-2008, 12:59 AM   #328
joe231
joe231's Avatar
hmmm....maybe you got a promotion?!?!?!
I like the horizontal, you could really tuck the wires up high, and hidden...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-12-2008, 01:03 AM   #329
Alan's Classic
[QUOTEI like the horizontal, you could really tuck the wires up high, and hidden...[/QUOTE]
Old 12-12-2008, 04:51 AM   #330
TimE
Hey Y'all!!
TimE's Avatar
I have to agree that the horizontal mount would look better.
TimE is offline   Reply With Quote
Old 12-12-2008, 08:54 AM   #331
tiggamonsta
tiggamonsta's Avatar
There is an unspoken rule with fuse panels. They must be installed in the most inconvenient location possible. Preferably one that requires a contortionist to access.
I like the horizontal.
tiggamonsta is offline   Reply With Quote
Old 12-12-2008, 11:38 AM   #332
kizer
Its Deja Vu time again
kizer's Avatar
Horizontal as well. Keeps the wires up nice and tight otherwise your going to have to have a big fat wiring loom to the left of your Fuse Box.
As for the unspoken rule I agree what the heck is up with that? Of course I worked on a Honda once and it had a split fuse box half behind each door and it really confused the heck out of me.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 12-12-2008, 02:46 PM   #333
SCOTI
SCOTI's Avatar
I also like the horizontal but . . ..... along those 'un-spoken-rules' mentioned, I think future service might be easier if they were coming out the side & then routed 90° up to keep them out of the way. This would allow some extra slack should the need for repairs sneek up on you (not that anything you install would fail).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-13-2008, 01:13 AM   #334
Alan's Classic
Thanks for the inputs.
Well GM came thru like they said. The ubolts came in and they actually gave me an extra. I had to go to the hardware store for lock nuts. GM doesn't offer them.
This a very nice and safe spring compressor that I borrowed. I think he said it is an OTC brand. It is pretty pricey he says.
This is as far as i could get the left front upper A arm bushing screwed in while on jack stands. I hope it will go further in. I'm sure it is supposed to be like the rear one.
Please excuse the dust.
Left side done.
Old 12-13-2008, 12:11 PM   #335
tommys66
I like the vertical mount. All the labels on the panel are for vertical mount, so if you were to see the panel I think mounted horizontal would look out of place.
tommys66 is offline   Reply With Quote
Old 12-14-2008, 01:47 AM   #336
Alan's Classic
That does make since, but I'd like to tuck it up higher so it's hidden. I'm so confused.
Both front springs and tierods are in still need to drill for the idler arm bracket. Wheel bearings are packed and installed (not pictured).
I used a roloc stripping wheel to clean the dust shields. It does good to clean everything but does leave minor scratch marks. It is not supposed to be used on a high speed grinder. It's not rated for high rpm's. Just throttle it down.
Old 12-14-2008, 08:56 AM   #337
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
so... does the fuse block have to be under the dash?
If you are going with all new wires and system, maybe a different more accessible spot would be better.
ideas:
on the inner fenderwell with a waterproof cover.
in, or access through the glove box.
in a floor console (if you have one).
on the outside of the firewall w/ waterproof cover.
on the outside of the driver fender right under the c/10 emblem ....just kidding with that one
Old 12-14-2008, 09:25 AM   #338
Alan's Classic
ideas:
You gave me an idea. What about inside the frame rail like under the driver. The brake and fuel lines run along the passenger side. Now i"ve got something else to dwell on. Thanks for the inspiration.
Old 12-14-2008, 10:40 AM   #339
jonzcustomshop
1961 crewcab
my sisters car reminded me.. she has a 2000-1? dodge neon, and the fuse box is crammed under the hood right next to the battery in a waterproof box. Took a while for an old timey car guy like me to find it there . right in plain sight btw!
framerail, it would be out of view, and a clean install, depending on how low you are , might be hard to get to to change one on the fly.
Last edited by jonzcustomshop; 12-14-2008 at 10:42 AM. Reason: cant speel my way out of a box!!! <lol can't even do that right!
Old 12-14-2008, 01:23 PM   #340
SCOTI
SCOTI's Avatar
I don't think the framerail is a possible choice on even a mildly lowered vehicle. To much possibility for the box to become submerged or become saturated w/moisture (we all know how effective water tight seals can be @ times).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-14-2008, 03:00 PM   #341
kizer
kizer's Avatar
Water and electricity don't play well together.
For me if its not where it normally goes it would be in the engine bay on the other side of that wall or under the seat somewhere.
Either way its gotta be up high enough so water doesn't get anywhere near it. One puddle could really screw up your day.
Old 12-14-2008, 09:29 PM   #342
Alan's Classic
Under the dash it is for the fuse panel.
Rolling frame
Here's a tag I got off of ebay that I will run on the truck
I took the girls Christmas shopping and saw this rolling down the road today.
Old 12-14-2008, 09:40 PM   #343
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
looks awesome Alan, I have one of those 65 GA tags on my truck.... Got asked by a Marietta police officer in a parking lot for my info, he didn't know you could do that.... Yikes... I took the advice of the dmv to carry the paper work and the real plate in the truck... After I showed him everything and educated him he was, lets say a little embarrased I should try no plate like the guy in the primer step!!
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 12-14-2008, 10:45 PM   #344
kizer
kizer's Avatar
Congrats on getting it on all 4's again.
Old 12-15-2008, 01:35 AM   #345
Dinos63
chevy only
Dinos63's Avatar
alan nice work,dig the two tone,solid work and clean as h-ll
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 12-15-2008, 08:44 AM   #346
4dranch
Shloooooong bed member #2
4dranch's Avatar
Alan and Old School,
explain how the old tags are used.
Alan,
Very clean, Thanks for sharing the pictures.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 12-15-2008, 05:10 PM   #347
jwart
progress looks great. are you running stock gas tank? Possibly if access allows. look at mount in cab corner, inside truck behind seat so you can get at it to change fuse & still very easy to get at an unused & protected space. pics on your progress & quality of workmanship are very inspirational. Hope it does lead to your own business someday. I'd recommend ya. JW
Old 12-15-2008, 11:27 PM   #348
Alan's Classic
Alan,
In GA we can take a year specific GA tag to the DMV and they will register the tag to that vehicle. For some reason they give you new tag to keep inside the vehicle. I don't understand that. I have not experienced it yet. The best thing to do is ask your DMV to see what can be done. Good Luck and thanks for the compliment.
Old 12-15-2008, 11:34 PM   #349
Alan's Classic
Thanks man, it's an accomplishment.
Thanks, I think the color contrast turned out good.
Thanks for the inspirational comment. Once the holidays are over I should be getting an aluminum fuel cell to go between the rails. Locating the fuse panel behind the seat is another good idea. I think I will stay with the traditional location. I'm bound to change my mind before I actually mount it.
Old 12-15-2008, 11:53 PM   #350
protrash64
Resistance is Futile
protrash64's Avatar
My friend and I replaced the bushings on my a-arms with the things sitting on the ground. We were each standing on the set of 3/4" drive rachets trying to get them broken off!!!!
We still laugh about that.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
