Old 03-26-2009, 03:33 PM   #26
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Rear Sway Bar
I don't think we got Nissan Pathfinders over here back then although they may have been called something else. IIRC we just got the Nissan Patrol and Terrano. The Pathfinder name only started to be used by Nissan here about a year or so ago.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-26-2009, 09:08 PM   #27
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: Rear Sway Bar
what size u-bolts do i need to fit the axle tube? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 03-26-2009, 09:17 PM   #28
rscam
Re: Rear Sway Bar
Here is a pic of the Pathfinder bar. It takes 3" muffler clamp. You have to elongate the hole in the clamp to get it round the axle tube. I will take some more tommorrow.
rscam is offline   Reply With Quote
Old 03-26-2009, 09:23 PM   #29
rscam
Re: Rear Sway Bar
hears another pic
Old 03-26-2009, 09:26 PM   #30
rscam
Re: Rear Sway Bar
And another. Its hard to get the right shot at the right angle. I will try some differen. ones tommorrow.
Old 03-26-2009, 09:56 PM   #31
vasquezmrysvll
"the other guy"
Re: Rear Sway Bar
so the axle tube is 3"?
Old 03-27-2009, 08:29 AM   #32
Andy4639
Old member
Andy4639's Avatar
Re: Rear Sway Bar
That's right I think 3" tubes. Sorry about the PM I hadn't woke up good. Yea this is right 3".
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-27-2009, 09:00 AM   #33
vasquezmrysvll
"the other guy"
Re: Rear Sway Bar
no problem, and thanks. other than drilling holes for the end link brackets, is it a bolt in?
Old 03-27-2009, 09:09 AM   #34
Andy4639
Old member
Andy4639's Avatar
Re: Rear Sway Bar
If you go to the orignal post about my install you have to have some 1" spacers on each frame rail. I had 2" ones cut. I had to cut them in half. I stilll have the other halfs.
Old 03-27-2009, 09:13 AM   #35
vasquezmrysvll
"the other guy"
Re: Rear Sway Bar
willing to come off the other one? (mods, sorry if this falls under the user WTB?)
Old 12-15-2009, 09:30 PM   #36
epashhans
epashhans's Avatar
Re: Rear Sway Bar
Originally Posted by big_al_71 View Post
I bought both of mine from CPP and the truck fells 100% better specially during lane changing at highway speeds and turning..
Hey big al, I got that same kit but haven't put it on yet. Curious why you didn't but it on top of the trailing arms? That way it wouldn't be hanging as low to catch stuff right?
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 12-15-2009, 09:47 PM   #37
jay6891
Car Knocker
jay6891's Avatar
Re: Rear Sway Bar
I have one too. Have been wondering if mounting on top of trailing arms matters or not. I think that I would like it on top. But instructions show mounted on bottom. Any suggestions.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 12-15-2009, 10:08 PM   #38
epashhans
epashhans's Avatar
Re: Rear Sway Bar
I was thinking I would like it on top as well. I looked at the instructions as well and see that its under the arms. I might try it both ways if I ever get it installed...-20 degree weather keeps me in the house!
I would be curious which is better out of the ones that mount to the arms and the ones that mount to the rear end. Anyone?
Old 12-15-2009, 11:21 PM   #39
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Rear Sway Bar
This is perfect for us leaf spring rear suspension guys, but where do the front ends mount to the frame?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 12-15-2009, 11:48 PM   #40
capev86
Re: Rear Sway Bar
i got the CPP bars for my 72 burb 3/4 ton 2wd factory height. it did not have the factory front bar and installing that 1-1/4 bar (bigger than the stocker) really made a night and day difference when coming to corners (it is stable and predictable now). installing the complimentary 1-1/8 will balance it front to rear, help keep the trailing arm system more aligned (doing poly bushings on the trailing arms and track bar too) and really make a difference when i have a big heavy trailer hitched up. the burb has more weight up high in the back than a pickup and thus more body roll, but any rear bar is better than no rear bar in any vehicle. front bar needs to be stiffer (aka bigger) but closer in size is better.
i put 87-89 lesabre t type sway bars on my 89 lesabre 4 door limited. went from 1-1/16 to 1-1/4 on the front and 1/2 to 3/4 inch on the rear. even though the rear got a bigger percent increase, the car still had too much under steer. a 1 inch bar would have been much better but the factory prefers under steer because it is safer for average joe drivers (you don't spin around backwards). i put the rear bar on first and i liked the balance but it still handled better overall once the bigger front bar was in.
capev86 is offline   Reply With Quote
Old 12-16-2009, 12:29 AM   #41
big_al_71
big_al_71's Avatar
Re: Rear Sway Bar
if my memory serves me right it said to install it the way I did.... now it is long gone as I upgraded my rear trailing arms and I was not going to drill them now the truck handles even better than it did..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-16-2009, 03:03 PM   #42
epashhans
epashhans's Avatar
Re: Rear Sway Bar
Big al, you installed it how it shows in the instructions. I am curious to know a little more in detail when you say that the truck handles even better now than it did...is that because of the new rear trailing arms? removal of the rear sway? Did you notice a difference when you had it on your stock setup once you put the sway bar on? Now I am really questioning myself for buying it...
Old 12-16-2009, 08:54 PM   #43
big_al_71
big_al_71's Avatar
Re: Rear Sway Bar
when I put the sway bar on the truck it felt stiffer on the side to side, keep on mind that I did not replace any of the trailing arm bushings. Now with the brand new trailing arms with urethane bushings it feels really nice and stiff, I had also added a front sway bar which is still in the truck.
If I was replacing the trailing arms I would not buy a rear sway bar only the front and if I was just going to rebuild the original arms with new bushings I would add the sway bar. The new arms are a square tubing one piece vs the stock style which is two halves so there is naturally more flexing if this makes sense.
Old 12-16-2009, 10:43 PM   #44
epashhans
epashhans's Avatar
Re: Rear Sway Bar
Thanks big al. I am sticking with my stock rear trailing arms (for now), so that gives me a little better piece of mind about having spent the money. Now I need to get them put on!
Old 09-04-2011, 01:52 AM   #45
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Rear Sway Bar
This was just posted by member sigshooter:
(figured the pics would be good in this thread also)
Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=482744
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-04-2011, 07:18 PM   #46
treveiger
treveiger's Avatar
Re: Rear Sway Bar
Interested
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 06-08-2021, 07:32 AM   #47
custom10nut
custom10nut's Avatar
Re: Rear Sway Bar
Here’s a question on this subject.
While members have said the late 80s Camaro/Firebird sway bars fit perfectly,
Will one off any of the other “Sport Models fit, width wise? (Like Impalas, Tahoes, Escalades? )
Just curious.
I’ve been so busy lately that I haven’t been to a yard since last year, but I’m going to be soon.
I’m compiling a list of things I need to look for now.
custom10nut is offline   Reply With Quote
Old 06-10-2021, 11:23 PM   #48
custom10nut
Re: Rear Sway Bar
Sub’d for future reference
Old 06-12-2021, 10:54 AM   #49
Arnulfo
Re: Rear Sway Bar
Thread:
This is the most effective method of attaching a torsion bar. Pivot points must be attached to frame and end of bar attched to either side of axel.
Arnulfo is offline   Reply With Quote
Old 06-12-2021, 12:40 PM   #50
custom10nut
Re: Rear Sway Bar
Do you remember what year Pathfinder you got the bar off?
