Old 03-17-2009, 02:16 PM   #1
mrh33916
Project '67 454
mrh33916's Avatar
Rear Sway Bar
Different people are using various junkyard rear bars on our trucks. Does anyone know of any bars that are readily available off any late model vehicles that fit well on a coil spring rear end?
Thanks,
mrh33916 is offline   Reply With Quote
Old 03-17-2009, 02:38 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: Rear Sway Bar
Third gen Camaros and Firebird
texanidiot25 is offline   Reply With Quote
Old 03-23-2009, 11:21 PM   #3
mrh33916
Project '67 454
mrh33916's Avatar
Re: Rear Sway Bar
Thanks for the input. I picked up the rear sway bar complete with brackets and bushings from a junk yard for 25 bucks, new Energy Suspension end links from Advance Auto Parts for 19 bucks, 5 bucks worth of nuts and bolts, and some cleaning and painting for a grand total of "49 DOLLARS". The diameter of the bar is .82". Here are some pictures of the sway bar installed. Name:  sway bar 1.jpg
Name:  sway bar 2.jpg
Old 03-24-2009, 05:21 AM   #4
Andy4639
Old member
Andy4639's Avatar
Re: Rear Sway Bar
Bar looks cool. Good job. Is it a Camaro bar or something else?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-24-2009, 09:31 AM   #5
mrh33916
Project '67 454
mrh33916's Avatar
Re: Rear Sway Bar
Thanks, It's from a Late 80's Camaro,
Old 03-24-2009, 12:54 PM   #6
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: Rear Sway Bar
Nice job. Good looking install and thanks for the pictures.
Question to you guys who have done the Camaro bar (or any bar for that matter)-- is it important where the bar is mounted? I've seen pictures of ones mounted to the trailing arms like mrh33916 did, as well as setups where they were mounted to the axle.
How do these differing setups effect the ride quality and/or rear stability and/or body lean?
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 03-24-2009, 02:34 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Rear Sway Bar
I'm not being a smart a** but I'm wondering why you decided to install a rear sway bar and what you hope to get out of it. Not a lot of guys put these on their trucks and in fact the guys at Early Classic Enterprises dont recommend or sell a rear sway bar for our trucks. With that being said I did install afront sway bar on my truck and noticed a difference in handling and feel in the first 100 feet after I installed it.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-24-2009, 02:52 PM   #8
monte0185
monte0185's Avatar
Re: Rear Sway Bar
Great looking install!! Couple questions though. Where did the brackets on the side of the frame come from and did you have to drill the holes in the trailing arms or are they already there?
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-24-2009, 02:53 PM   #9
69chevybmx
69chevybmx's Avatar
Re: Rear Sway Bar
A rear bar will further reduce the amount of body roll. The performance increase from a rear bar does not compare to that of a front bar upgrade but there is still a noticeable difference.
Even if there were no performance gain, it still looks good.
69chevybmx is offline   Reply With Quote
Old 03-24-2009, 03:11 PM   #10
Andy4639
Old member
Andy4639's Avatar
Re: Rear Sway Bar
I couldn't really tell that it helped it any until I drove it through some pretty good curvse at a good speed. That's what it helps with. I for one have a old back road I take to work that has a couple of nice curvse on it and it made the truck feel a lot better in the middle of them than before with out it. Mine is a Camaro bar also.
Old 03-24-2009, 03:13 PM   #11
big_al_71
big_al_71's Avatar
Re: Rear Sway Bar
I bought both of mine from CPP and the truck fells 100% better specially during lane changing at highway speeds and turning..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-24-2009, 03:44 PM   #12
Already Gone
Re: Rear Sway Bar
Is your truck lowered?
Old 03-24-2009, 03:57 PM   #13
67chevemall
67chevemall's Avatar
Re: Rear Sway Bar
All three are mounted different. Always wondered where the OEM placement is.....
mrh that looks mint...is that OEM bar>?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-24-2009, 04:10 PM   #14
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: Rear Sway Bar
Was there an OEM placement?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 03-24-2009, 04:12 PM   #15
big_al_71
big_al_71's Avatar
Re: Rear Sway Bar
Yes it is.....3 inches in the front 5 in the rear...
Old 03-24-2009, 04:23 PM   #16
Already Gone
Re: Rear Sway Bar
Cool looking truck. I am planning a 3 1/2 front and 5 rear drop for my truck and now I know the rear bar works I guess I'll have to get one for my truck.
Old 03-24-2009, 05:13 PM   #17
Lugnut64052
Re: Rear Sway Bar
I've seen Andy state a few times that there was an OE bar for 1-tons, which would be a leaf spring rear. Don't believe there was ever a coil spring rear bar. I'm curious to know how the OE bar laid in there.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-25-2009, 11:03 AM   #18
67chevemall
Re: Rear Sway Bar
Me too! Andyu to the rescue
Old 03-25-2009, 01:22 PM   #19
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Rear Sway Bar
I'm interested in this as 80's camaros are relatively plentiful in American car terms over this side of the atlantic so theres always some around getting broken for parts. Exactly what models would I be looking for and what years? What parts exactly do I need? I'm happy fabricating brackets if I need to. We have lots of what I think you guys call Traffic Circles (we call em roundabouts) here in the UK so anything that will help the handling would be good. I've got the largest stock front bar (came off an 80's camper) with lowered brackets and poly bushes from ECE. Flipping thing is hugely thick and weighed a ton, well it felt like it after I carried it about a mile back to the car when I collected it from a guy at a big car show!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 03-25-2009, 01:40 PM   #20
nightmare
nightmare's Avatar
Re: Rear Sway Bar
phil, a lot of times, the brackets that you need are on the camaro or firebird. just make sure you get everything that would mount it to the truck. you want to look for either an IROC, Z28, or TA, anything from '82 on up. these have the bigger rear sway bar. I've got a '95 TA WS6 bar on mine.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 03-25-2009, 03:18 PM   #21
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Rear Sway Bar
Thanks for the info, I'll put some feelers out to see what I can find. Would be nice to make it handle a bit better, I know its no racecar but where I live the roads are quite narrow and winding so body roll is a bit of an issue. It left the factory as a real plain jane with a six banger under the hood and no sway bar and going round some of our UK sized traffic circles it was almost scraping the door handles on the ground. The front bar has made a huge difference but a rear one should make it a little better still.
Phil
'67 C10 long fleet.
Old 03-25-2009, 03:51 PM   #22
neonlarry
neonlarry's Avatar
Re: Rear Sway Bar
Phil, here is a link to an old post about using the camero bar. You can also see another way of mounting the bar in my pics
http://67-72chevytrucks.com/vboard/s...hlight=swaybar.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-25-2009, 05:07 PM   #23
mrh33916
Project '67 454
mrh33916's Avatar
Re: Rear Sway Bar
I have a C-notch kit installed on mine, that's why I mounted it where i did. As best I can tell there will be no clearance issues regardless of how low the truck ends up when I'ts finished.
Old 03-25-2009, 08:51 PM   #24
rscam
Re: Rear Sway Bar
I put a Nissan Pathfinder sway bar on my 69 GMC. I have leafs and it fits perfect. $15 at Pullapart. Its the perfect width for the frame so you don't have to fab any brackets. Just drill two holes in the frame. Its a 1" bar also. I mounted it to the rear axle with 3" muffler clamps.
rscam is offline   Reply With Quote
Old 03-25-2009, 08:54 PM   #25
rscam
Re: Rear Sway Bar
By the way the Pathfinder bar is on 87-95 models. It should fit coil rears also. I looked and measured one day at Pullapart and it appears it will fit to me.
