Old 03-22-2009, 04:24 PM   #1
BrokeandDreaming
72 2wd lift?
I have a 72 C20....I really want to do a 4x4 conversion. Unfortunatly, funds wise it will take me a while to pull the funds together to to the four wheel drive thing, so........does anybody know of any way to do a lift on a 72 C20, relatively affordable?
BrokeandDreaming is offline   Reply With Quote
Old 03-23-2009, 11:43 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 72 2wd lift?
Have you considered a body lift?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-25-2009, 07:43 PM   #3
BrokeandDreaming
Re: 72 2wd lift?
Not a fan of body lifts at all, the looks of the, jacking steering angles up....just can't stand them.........
Old 03-26-2009, 11:30 PM   #4
pcorriveau951
pcorriveau951's Avatar
Re: 72 2wd lift?
One way to accomplish i lift on these 2wd is to lower the cross member, i ran across a a early 60's truck done this way yesterday, i talked to the owner and he said that it rode just like before just took some time to fabricate. Im going to swing by a take some pictures of it tomorrow night on my way home and then ill post them up to show you what he did.
pcorriveau951 is offline   Reply With Quote
Old 03-27-2009, 11:31 AM   #5
BrokeandDreaming
Re: 72 2wd lift?
Right on and thank you. I figure that the suspension on these trucks hasn't changed a whole lot until you get to the early 2000's, so there has to be a way, even if it's mix matching parts. I'm starting to think that if it's going to become expensive that I might as well switch it to four wheel drive........
Old 03-28-2009, 07:59 PM   #6
pooz911
pooz911's Avatar
Re: 72 2wd lift?
3 inch body lift, suspension lift and 33 inch tires.
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 03-28-2009, 08:24 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 72 2wd lift?
Sweeet!
Articles-
"Refining Sierra"
Old 03-29-2009, 04:03 PM   #8
pcorriveau951
Re: 72 2wd lift?
still trying to get those pics the guy hasnt been home when i have gone by with the camera.
Old 03-29-2009, 06:30 PM   #9
BrokeandDreaming
Re: 72 2wd lift?
How did you get the suspension lift on the blue truck? and is there a gap above the rear bumper from the body lift?.....I am interested in the crossmember lift, I'm assuming this is something I can do at home with a welder and material, is a tubing bender needed? Thanks guys
Old 03-29-2009, 07:40 PM   #10
pooz911
pooz911's Avatar
Re: 72 2wd lift?
The front suspension is lifted by Rancho Springs, 1 inch upper ball joint spacer and the rear is completely stock (including the original shocks). the front frame horns were cut and moved up 3 inches, braced and welded back up. The rear bumper brackets was moved up and bolted/welded in. I am not using the ball on the bumper. I had a drop hitch welded into the frame for all of my towing needs. If you need, I can post some pictures of the back
Old 03-29-2009, 07:47 PM   #11
pooz911
pooz911's Avatar
Re: 72 2wd lift?
I am also very interested....If you can, please get the details and pictures on what he did for the steering.
I knew of someone who lowered the crossmember but the steering geometry was off. They took two idler arms and placed a block of steel in between to make up the 3 inch difference, however to clear the crossmember it actually shortened the throw of the pitman arm, thus making the turning radius very short. (he couldn't make a 3 point turn, it was more like a 5 point turn) \
thanks
Old 04-05-2009, 04:34 PM   #12
pooz911
pooz911's Avatar
Re: 72 2wd lift?
bump......
Any luck on those pictures???
Old 04-06-2009, 01:13 AM   #13
pcorriveau951
Re: 72 2wd lift?
still trying to get them, havent been able to get ahold of the owner to get the pictures.
