Old 12-18-2000, 04:38 PM   #1
wacko
Post Driveshaft
Has anybody had any luck with replacing the double driveshaft in a 66 with a single piece shaft? I'm getting really tired of dealing with that center support bearing. I have a TH350 behind a 327. Is there a junkyard shaft that I can bolt in, or one that I can have cut down and rebalanced? I obviously prefer one that I don't have to mess with. Does the driveshaft loop ever create clearance problems with a new shaft?
wacko is offline   Reply With Quote
Old 12-18-2000, 04:48 PM   #2
ImpalaSS
Exclamation
my 66 shortbed gmc parts truck with leaf rearend had a 1 piece i think,,,
atleast it didnt have any driveshaft loop part etc
i dont have the driveshaft from it but maybe you should look for a leafspring truck?
xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside
64ImpalaSS 68 large journel 327 turbo 350
ImpalaSS is offline   Reply With Quote
Old 12-19-2000, 08:09 PM   #3
67_SS396
Post
The short beds I have owned always had the one piece drive shaft. You didn't say if you had a short or long bed. Plus I have not seen the loop cause any clearance problems except for exhaust routing.
Good luck
67 SHORT STEP 396/Powerglide, 3.73's All the normal go fast
goodies. Power discs and
power steering. Needs AC
2000 Silverado
1998 Nissan Frontier
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 12-20-2000, 12:23 PM   #4
wacko
Post
It's a longbed.
Old 12-23-2000, 08:07 PM   #5
bbs1965
Open Sundays 10 till 10
Post
I have had and have a lwb truck with built motors. I hate those carrier bearings they really suck. I have heard late model one piece driveshafts will work, but i've never seen it done. I was almost certain that the angle you would put your driveshaft at would wear out your pinion seal on your rearend.
As lame as this advice is. I carry a spare driveshaft in my truck complete set up bearing and all. I'm wondering myself if i installed a long tail 350 turbo with a custom built driveshaft would it work. Probably have to do some torching on the crossmember and reinforce frame in another spot. I'm open for suggestions.
parts for sale always
30 minutes south of Dallas on I35
WWW.BBSAutoSalvage.com
bbs1969@direcway.com
bbs1965 is offline   Reply With Quote
