A/C Clutch removal
In order to get the compressor off the bracket I have to remove the AC Clutch. I got the nut off the center of the AC Clutch how do I get the rest of it off? Thanks!
My Truck's not leaking its marking its territory! |
#2 | |
Unfinished Project Club
![]() Join Date: Jul 2005
Re: A/C Clutch removal
if you are just remove the three nut and bolts they run through the body of the unit and pull the whole thing up and out. The bolts have one side of the head ground down so it will slide past the A/C clutch . hope this helps Randy
![]() ![]() ![]() ![]() ![]() ![]() ![]() Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas ![]() 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 08-05-2009 at 05:30 PM. |
#3 | |
UPDATE: I finally got that bugger off. O'Reily Auto Parts had a kit you can barrow. It has a threaded sleeve that screws into the center of the hub that has a ram screw that goes down the center of it. Then the snap ring and the pulley finally comes off. What an itch if you have never done it before. It is easy now that I've done it. Finding the correct tool is the major battle.
Glad you got it off, I was gunna tell you you'll need an A/C clutch puller. I have one I picked up when I was at carlisle truck Nats last year. It makes the job alot easier.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#6 | |
but Im glad you got it off. ![]()
![]() ![]() ![]() ![]() ![]() ![]() ![]() Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas ![]() 1993 Jeep Cherokee. Looking for a swb chevy 73-87 Last edited by lvschevytrucks; 08-07-2009 at 01:02 PM. |
#7 | |
My Truck's not leaking its marking its territory! Last edited by 87Bob; 08-07-2009 at 02:02 PM. |
blood type; Retumbo
upon reassembly make sure the gap is .012 - .015"
how is the clutch face? is it square and flat or kind of wavy? how is the bearing? you may want to check these out before you powder coat a bad clutch. |
