Wheel Tub ?
What is the different in 65 -66 wheel tubs and 67 -72 wheel tubs.
Re: Wheel Tub ?
The arch and hole pattern is slightly different between the '60-'66 & the '67-up, so they are not a direct bolt-in and the horizontal flange does not have the raised areas to accept the wear strips, as on the '60-'66 Chevy/GMC tubs. I have purchased the '67-'72 inner wheel tubs, that are being sold as a good replacement, but they are not a good replacement and require some metalworking in order to make them fit and they do not have the same configuration on the inside exposed surface.
Re: Wheel Tub ?
