Old 12-28-2009, 02:07 AM   #101
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Check this out..........That is not going to work, Please pick a more "family friendly" avatar.
smokedat is offline   Reply With Quote
Old 12-28-2009, 02:44 AM   #102
smokedat
smokedat's Avatar
update
Next up i will be installing power lock actuators (key less entry) and alarm system with remote start.
parts:
alarm Viper 5901
2- actuators
2- 5 wire relays
wire
Old 12-28-2009, 02:46 AM   #103
smokedat
smokedat's Avatar
I will post more pics after i finish the alarm install.
Old 12-28-2009, 02:55 AM   #104
smokedat
smokedat's Avatar
If you can get your hands on 5 wire relays on the cheap and would like to go that route, this is how to wire it up. the benefit of this method is when one wire is energized the other will remain ground, and vice versa. this means you only need 2 relays instead of 4.
Old 12-28-2009, 09:02 AM   #105
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by smokedat View Post
Check this out. New Avatar
Dude! Don't know if that avatar will fly?
Old 12-28-2009, 09:51 AM   #106
joe231
joe231's Avatar
it won't......
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-28-2009, 09:53 AM   #107
menace121978
menace121978's Avatar
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-28-2009, 01:25 PM   #108
3r!c84
Badass
3r!c84's Avatar
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-28-2009, 02:46 PM   #109
smokedat
smokedat's Avatar
My bad hope this 1 works
Old 12-28-2009, 02:49 PM   #110
joe231
joe231's Avatar
Mo' Betta'
CHEVY ONLY
Old 12-28-2009, 04:13 PM   #111
mcbassin
Still Learning
mcbassin's Avatar
Much better...how about "BAD MUTHATRUCKA"
Old 01-04-2010, 01:12 PM   #112
smokedat
smokedat's Avatar
Update- still waiting on parts but i finished up the alarm and door lock actuators. I also installed a hood pin switch that triggers alarm, here are a few pics.
Old 01-04-2010, 01:15 PM   #113
nlped
nlped's Avatar
Cool progress!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-04-2010, 02:18 PM   #114
mcbassin
Still Learning
mcbassin's Avatar
Fine looking alarm system!
Old 01-04-2010, 03:03 PM   #115
joe231
joe231's Avatar
that is cool!
care to elaborate on it? brand? is it vehicle specific?
CHEVY ONLY
Old 01-05-2010, 03:31 AM   #116
smokedat
smokedat's Avatar
Originally Posted by joe231 View Post
that is cool!
No problem this is the Viper model 5901 for vehicles and it comes with two remotes one is like a pager so it vibrates and it displays different things, it has a onboard lithium-ion rechargeable battery with mini-USB for recharging
In remote start mode, if Active Temp Check is selected, Responder LC3 will display Temperature (in either Fahrenheit or Celsius) instead of the time (the default display). Now you can see the actual temperature inside the vehicle, before walking through the weather to get to it! If it isn’t warm enough inside your car yet, use Runtime Reset to extend your runtime. Don’t worry about forgetting about your car – Responder LC3 reminds you 3 minutes before your time runs out, with an audible tone, a vibration, and on the screen.
If anything happens to your vehicle, it notifies you right away if you are within range, playing the Revenger siren tones from inside your pocket. If anything has happened to your vehicle during your absence, LC3 spells out what happened Shock Sensor, hood open, door open for example.
Control Center – combines the Status LED and Valet Switch with the 2-way Antenna, making the switch easy to locate, and eliminating drilling of any holes in the dash
# of Remotes 1 Responder LC3 2-Way and 1 5-button 1-Way
Range Up to 1 Mile
Security Yes
Remote Start Yes
Keyless Entry Yes
SmartStart Compatible Yes
Encryption SuperCode™
Domelight Supervision Yes
Stinger DoubleGuard Shock Sensor Yes
Neo Revenger 6-Tone Siren Yes
Failsafe Starter Kill Yes
Anti-Carjacking (VRS) No
Guaranteed Protection Plan (GPP) Yes
Auxiliary Channels for Optional Functions 4
Remote Control Trunk Pop Yes
Cool thing is that u can do pretty much anything with the auxiliary channels such as roll up roll down windows pop doors open if u have shaved door handles, control youre air bags pretty much anything you want.
I highly recommend this alarm system to anyone.
Old 01-05-2010, 08:26 AM   #117
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
I like this build. Your truck is going to be wicked I need to get a good alarm for my 79 GMC. I will be checking into this one. I like the remote start option and all the remote functions. How is your LS build coming? Will be pulling my old engine this weekend getting ready for my 6.0l swap.
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline   Reply With Quote
Old 01-05-2010, 09:31 AM   #118
joe231
joe231's Avatar
Thanks for the info!!
CHEVY ONLY
Old 01-06-2010, 08:59 PM   #119
smokedat
smokedat's Avatar
How is your LS build coming? Will be pulling my old engine this weekend getting ready for my 6.0l swap. [/QUOTE]
Its slowly coming together still waiting on parts, good luck with you're swap, will stop by you're build thread to check it out.
Old 01-06-2010, 09:08 PM   #120
smokedat
smokedat's Avatar
Update finally got some parts in. I got the A/C compressor billet cover, i got my twin horn and air filters, billet straight neck thermostat, Lockar column arm kit, and a tube bender from Imperial bends 3/16, 1/4, 5/16 and 3/8 in. O.D. tubing for my fuel lines and trans lines.
Old 01-06-2010, 09:11 PM   #121
smokedat
smokedat's Avatar
sum more
Old 01-06-2010, 09:14 PM   #122
smokedat
smokedat's Avatar
A/C compressor billet front cover, some before and after shots.
Old 01-07-2010, 01:14 AM   #123
mcbassin
Still Learning
mcbassin's Avatar
some nice looking Bling! Dude, I wish we had half your budget. Keep the pics coming!
Old 01-07-2010, 08:44 AM   #124
silvereagle07
silvereagle07's Avatar
The pulley covers look great. I was wondering, does that type of air inlet system cause problems with heat soak? Either way the dual air intake looks cool.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-07-2010, 09:04 AM   #125
Thealien
Thealien's Avatar
Let me know how you like the tubing bender and how much it was, I need to get one soon. Hw much was the whole intake air filter set up?
Looking great!
Thealien is online now   Reply With Quote
73c10, c10, cheyenne, ls1, swap
