Old 05-27-2010, 07:53 PM   #1
GM72K10
Next!
GM72K10's Avatar
86 k/30 c & c
Picked up an ex firetruck GSA K31003 K30, 6.2, 4:56s, 4 speed, Dana 60, NP205, etc dually, 28K original miles, NO RUST. Check out the dual exhaust in the back of this so they could clear PTOs, driveshafts, etc. Came minus the firetruck body and minus brakes!
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 05-27-2010, 07:57 PM   #2
USSkoval
Re: 86 k/30 c & c
What's that tank on the upper radiator hose for?
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-27-2010, 08:35 PM   #3
Mike C
Mike C's Avatar
Re: 86 k/30 c & c
Appears to be a heat exchanger. Probably a hydraulic fluid cooler of some kind. Cool truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-27-2010, 10:50 PM   #4
PureLuck88
PureLuck88's Avatar
Re: 86 k/30 c & c
yea looks to be a cooler for the pto
PureLuck88 is offline   Reply With Quote
Old 06-15-2010, 09:39 PM   #5
GM72K10
Next!
GM72K10's Avatar
Re: 86 k/30 c & c
Finally got around to making her run. Needed extra fire truck apparatus wiring removal, (never seen so much wiring crap under the hood and dash)
batteries wired correctly, grounds cleaned, new glow plugs and controller. Has good clutch, probably first time its run in 4 years, started right up, runs like a champ and moves under its own power. Now all we need is a dump body for it.
86 K30 CUCV M1028A1
Old 06-16-2010, 11:01 PM   #6
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Re: 86 k/30 c & c
Just picked up a 76 K30 c&c yesterday. 2wd though. Still equipped with all the goodies. And only 9400 miles.
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 06-17-2010, 12:25 AM   #7
chevymotocross
chevymotocross's Avatar
Re: 86 k/30 c & c
You guys have some nice workhorses there! Both of you being from the "rust belt", I WISH my truck was as clean as those. Look at that damn frame on your truck.... looks like it came off the show room floor! I'm currently working with swiss cheese.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 06-17-2010, 05:34 AM   #8
GM72K10
Next!
GM72K10's Avatar
Re: 86 k/30 c & c
Nice truck! You have a C30 though, K30 makes it a 4x4.
86 K30 CUCV M1028A1
Old 06-17-2010, 07:43 AM   #9
grinch4om
dang its hot
grinch4om's Avatar
Re: 86 k/30 c & c
could you take some close up pictures of the spot light? I am curious as to how they mounted it...
grinch4om is offline   Reply With Quote
Old 06-17-2010, 09:04 AM   #10
Savage
Savage's Avatar
Re: 86 k/30 c & c
i second this
United States Marine Corps
1986 USMC CUCV M1008 (daily driver) / 1984 Chevy K10 RCLB
Savage is offline   Reply With Quote
Old 06-17-2010, 09:11 AM   #11
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: 86 k/30 c & c
You drill a hole all the way through your pillar. The spotlights have keepers at either end that are adjustable so the light will fit a variety of different ways. It's a simple design, been used for decades.
We do collision repair on emergency vehicles every so often, and always cringe when we have to mess with a spot light or light bar. Not so bad just removing it and putting it back in the same panel, but when you replace a panel and have to drill it and install it, it's a PITA.
RandyP is offline   Reply With Quote
Old 06-17-2010, 01:23 PM   #12
grinch4om
dang its hot
grinch4om's Avatar
Re: 86 k/30 c & c
understand that RandyP but there isn't much pillar on these trucks, just want to see one close up
Old 06-22-2010, 09:44 PM   #13
GM72K10
Next!
GM72K10's Avatar
Re: 86 k/30 c & c
some pictures of the spotlight mounting inside and outside
86 K30 CUCV M1028A1
