Countdown Survivor
Wheel offset calculators & offset explained
There have been several questions asked concerning ofset and swapping wheels lately so I thought I'd do a Google for some easy to understand info, here's some of what's out there:
Offset Calculator 1010Tires Offset Calculator GTSparkplugs Wheelsandtires.com Tirerack.com Wheel Offset explained TireRack Wheel Tech Articles
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
Old Skool Club
![]() Join Date: Jun 2001
Re: Wheel offset calculators & offset explained
Thanks for putting this info together for us all.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Home Built '87
Wheel Backspacing and Offset
Before mounting a set of aftermarket wheels, there are some dynamics involved with fitment that are best to understand first. 1. Wheel Diameter. This is the diameter of the wheel. Stock wheels are commonly 15 or 16 inch diameter. This dimension is usually in 1 increments (i.e. 15, 16, 17) but some manufacturers offer 16.5, which is rare. 2. Wheel Width. This is the width of the wheel, measured inside the outer lip of the wheel. This dimension is usually in 1/2 increments (i.e. 7.5, 8) 3. Wheel Center. This is the center of the wheel in relation to the width. 4. Offset. The distance from the centerline of the wheel to the face of the mounting surface of the wheel that contacts the hub. 4.1 Zero Offset. Indicates the mounting surface is at the wheel center. 4.2. Negative Offset. Indicates the mounting surface is behind (or inboard) the centerline of the rim. This is often found on standard rear-wheel-drive vehicles and on so-called reversed rims. (Diagram below shows negative offset) 4.3 Positive Offset. Indicates the mounting surface is in front of (or outboard) the centerline of the rim. This is often found on front-wheel-drive vehicles. Stock Tacoma wheels have Positive offset. 5. Backspacing. The distance from the mounting surface to the inside lip of the wheel. This measurement is closely related to offset (without actually measuring, backspacing is about equal to [Wheel Width / 2] + [Offset] + [about 1/4] ). 6. Centerbore. The centerbore of a wheel is the size of the machined hole on the back of the wheel that centers the wheel properly on the hub of the car. This hole is machined to exactly match the hub so the wheels are precisely positioned, minimizing the chance of a vibration. This measurement may be critical to clear the hubs of a 4WD. 7. Bolt Circle. Also known as PCD (Pattern Circle Diameter). The bolt circle represents the diameter of an imaginary circle that goes through the center of the bolt holes. 4x2 Tacoma Bolt Circle: 5 lug on 4.5 PCD; 4x4/Prerunner Tacoma Bolt Circle: 6 lug on 5.5 PCD.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
more confused im thinking on putting a 17x9 in the rear of my 66 c10 can some one help me with just giving me the correct backspacing 17x8 up front
Tot Roddin'
SRVBLUES64 - there's a lot more at stake than just offering BS numbers. We need some additional info:
Are you running drums or disc brakes? Are you running drop spindles? How much drop? Static/Bag drop? What size tires are you wanting to run? Did you swap in a late model crossmember? Etc.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
more info Im putting 2.5 drop spindles and 5 lug disc conversion up front with drum set up in the back with new axles fro 5 lug and I think a 4 inch drop, as for wheels 17x8 with 255x60x17 front and for the back 17x9.5 with 275x60x17 it should have a rake with a hot rod stance. I took a pic of the rear end I do not know the size or lenght I hope thats what your asking I will check in the morning I hope that helps Thanks Jeff
Tot Roddin'
What width is the rearend?
#8 | |
Kim http://www.stocktonwheel.com/wheel_guide.php |
Happy to be here
![]() Join Date: Mar 2000
This is now in the FAQ forum- LINK
