Old 08-10-2010, 05:47 PM   #1
coater
Was going to upgrade instruments until......
Was going to upgrade my gauges when I put my new engine in my'85,and WOW!!! I can't believe the prices of the Autometer gauges. I figured I would have close to $450 just in gauges,I can't believe they are that expensive. They are proud of them for sure.
Has anyone had good luck with accuracy with your stock gauges. Or if someone knows a better gauge company besides Auto $$$$$$.
Thanks guys!
coater is offline   Reply With Quote
Old 08-10-2010, 06:13 PM   #2
87GMCChris
87GMCChris's Avatar
Re: Was going to upgrade instruments until......
My stocks are pretty accurate, except one... oil pressure. Will read zero when hot. Put in a new oil sender, same deal. Ended up putting a T fitting beside the distributor and the running that to a mechanical gauge under the dash, i got from canadian tire. Just a 20 dollar gauge but it work just fine. Now reads 20psi hot.
1987 GMC Wrangler - 305TBI/TH400/Duals
1968 Camaro - Resto
2010 Ranger
I only drive truck 6 months a year... Dam Canadian winters.
87GMCChris is offline   Reply With Quote
Old 08-10-2010, 07:20 PM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
Try www.iequss.com
they are sold locally at o'reilleys
Stitch is offline   Reply With Quote
Old 08-10-2010, 07:28 PM   #4
cableguy0
Most of the time you get what you pay for. Autometers are extremely accurate and thats what your buying. I put autometers in my dash but started kinda cheap. I had an autogage tach and a 3 gauge panel so i used them for the time being and am going to replace 1 by 1 with autometer stuff so everything matches.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-10-2010, 08:08 PM   #5
coater
I guess if I buy 1 at a time maybe it won't feel so bad on wallet. I haven't looked a gauges for years and would have thought there would be another good company by now.
Old 08-10-2010, 08:16 PM   #6
Davidmichael
Davidmichael's Avatar
I would start to buy them 1 by 1 and just stock pile the parts until complete.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 08-10-2010, 08:38 PM   #7
S10Fan
Old Heap Driver
I have Sunpro electric gauges in my S-10. The water temp gauge is off by 25-30 degrees. I called their tech line and was told I could expect a 20 degree discrepancy, yep, 20 degrees. My AutoMeter speedometer and Tach work flawlessly.
I plan to replace all of them with AutoMeter units in the near future.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-10-2010, 08:57 PM   #8
menace121978
menace121978's Avatar
just ordered my ultra lite II's yesterday its only money!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-10-2010, 09:54 PM   #9
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
$500-$800 isnt bad if you say it real fast! Like Dennis said, it's only money, you cant take it with you when you die, might as well spend it now!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-10-2010, 10:13 PM   #10
AceX
>130dB Moderator
AceX's Avatar
Welcome to car culture. My name's Bankroll and I'll be your reality check for the day.
Sterwart Warner I wasn't impressed with. "Our tolreances are set to within 10% of actual"
10% on a $25k motor is not acceptable... Autometer is known for being very accurate and their quality control is top notch. Spending an extra $20 for a temp guage is nothing compared to the $3000+ for a new motor...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 08-10-2010, 10:39 PM   #11
coater
I guess I could go ahead and order the tach. Autometer has a $60.00 rebate on the tach I want. That will bring the price down to $92.00. I need the temp and oil pressure to put on engine breakin stand,so I can breakin the engine.
Old 08-10-2010, 10:49 PM   #12
menace121978
do it!!
"Dennis the Menace"
Old 08-10-2010, 10:53 PM   #13
bigblock73
yeller
bigblock73's Avatar
Are you doing a surface mount or recessed?
I have those, had them surface mounted, and now in the middle of recessing them. If you recess, let me know, I might be able to share some pointers with you.
Autometers are worth the coin, as mentioned accuracy is second to none, and the quality and support is great.
bigblock73 is offline   Reply With Quote
Old 08-10-2010, 11:01 PM   #14
coater
I'm going to recess them. There was a guy on this site that had done it and it looks real nice. I like the recessed look,makes it look more original to me.
Old 08-10-2010, 11:14 PM   #15
flamingbig10
6.0 powered square
flamingbig10's Avatar
I used some dolphin gauges and installed them on a stock bezel with sheet metal its not prettiest but I needed my truck that day
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-11-2010, 04:31 AM   #16
menace121978
Jeff, i'm going to recess them. any insight would be great buddy. thanks!
"Dennis the Menace"
Old 08-11-2010, 08:51 AM   #17
bigblock73
yeller
bigblock73's Avatar
Dennis, the main things you should know are that you will need to trim the rings down on the back side of the bezel, you will need to remove the rings from your new gauges and have to epoxy the lens and inner ring to the gauge body. You will also have to come up with a way to mount them. I have seen them wired in with piano (or similar) wire, and I have seen them glued directly to the cluster. I was not about to glue mine, so I tried to wire them in...that turned out to be a PITA, so I am trying something different. I designed alum brackets that will connect the gauges together, and they will be fastened to brackets that are either mechanically or adhesively adhered to the bezel. I should be getting these back from the CNC shop this week, and will install them and post pictures. If it works out, I should be able to get you a set of brackets, you just pay for the cost and shipping. If these end up being in demand, then I may make more and sell for a small profit.
Before you start tearing apart your gauges, we should talk, I have a few other pointer for you, that will save you some hassle and potentially keep you from messing up your gauges.
Just let me know what you think.
Old 08-11-2010, 10:20 AM   #18
blazer2007
If you buy them in a set of 3,usually your main gauges like oil water and volts is alot cheaper,that will keep you busy until you get more money.I bought mine at NAPA and I was told eqquus is made by SW
blazer2007 is offline   Reply With Quote
Old 08-11-2010, 10:45 AM   #19
zeewhiz
Originally Posted by Fat Hoe View Post
Try www.iequss.com
This. I had a full set on my old '85 300ZX turbo... no complaints whatsoever.
zeewhiz is offline   Reply With Quote
Old 08-11-2010, 10:57 AM   #20
355bullet
355bullet's Avatar
Cant go wrong with Autometer, best in the business. i have those in the nova also...and getting ready to intall a tach in my truck. you get what you pay for.
Same here, i bought mine one @ a time, then installed them when i got the set.
355bullet is offline   Reply With Quote
Old 08-11-2010, 04:10 PM   #21
coater
Bigblock you can count me in on those brackets.I'm like you I couldn't glue them in.
Old 08-11-2010, 06:32 PM   #22
menace121978
pm sent Jeff
"Dennis the Menace"
Old 08-12-2010, 12:49 AM   #23
givengold
I'm good for a set of brackets as well. Keep us posted.
givengold is offline   Reply With Quote
