Old 09-29-2010, 10:59 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
4.8 to 5.3 conversion cam question
I have a 4.8 I'm making a 5.3. I have the floating pin flat top pistons, 862 heads and a cam with .467/.479 lift from an LS1. The stock lift is .457/.466.
The questions I have are do I need to use other than the stock 862 valve springs and do I need to be worried about the piston hitting the valve with the flat tops.
My thinking was its almost stock and should be no issue but I'm not up on LSx motors
Old 09-29-2010, 11:38 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 4.8 to 5.3 conversion cam question
...now I thought the bore of the 4.8L and 5.3L was the same...and that the stroke was different.....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-30-2010, 12:09 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
correct, I should have said I changed the crank, rods and piston to make it a 5.3
Old 09-30-2010, 01:14 AM   #4
Super73
Super73's Avatar
If you have 5.3 rods and pistons you should be fine. If you have 4.8 rods with 5.3 pistons, I can't answer your question as I don't know the rod length...
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-30-2010, 02:22 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I purchased a 5.3 crank, rods and flatop pistons. I thought it would be ok but didn't know for sure.
Old 10-07-2010, 09:14 PM   #6
blazerboy72
Do you have 4.8 rods and pistons too? The 5.3HO is really just a 4.8 with a 5.3/6.0 crank, if you want a little extra compression.
blazerboy72 is offline   Reply With Quote
