View Poll Results: For those of you laying frame, how tall are your front tires
under 28 inches tall 13 33.33%
over 28 inches tall 26 66.67%
Voters: 39. You may not vote on this poll
Old 04-07-2011, 07:22 PM   #26
Jeebus
Jeebus's Avatar
Re: Survey- For those of you laying frame, how tall are your front tires
32.75 here, but thats probably not much help at all.
Taylor
Oops!
Jeebus is offline   Reply With Quote
Old 04-08-2011, 09:20 AM   #27
67cheby
67cheby
67cheby's Avatar
Taylor
holy smoke......you running 26's ????
67cheby is offline   Reply With Quote
Old 04-08-2011, 10:03 AM   #28
lolife99
67-72 parts collector,…
lolife99's Avatar
24's,... I think.
Keith
Convert to disc brakes.
Old 04-08-2011, 01:31 PM   #29
Jeebus
Jeebus's Avatar
305-35-24
btw, dont trust those tire calculators fully, they are great for estimating what the tire size will be, but each tire is different. By those tire calculators my tires are 32. Get them inflated, and on my shop floor, they are 32.75 off the ground.
Taylor
Oops!
Old 04-08-2011, 01:36 PM   #30
67cheby
67cheby
67cheby's Avatar
hmmm...good to know
Old 04-08-2011, 01:36 PM   #31
67cheby
67cheby
67cheby's Avatar
Jeebus, do you have a build thread ??
Old 04-08-2011, 01:48 PM   #32
m6z
m6z's Avatar
I'm planning on a 28" tire right now, but if you made them taller I'd consider going 22's all around.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 04-08-2011, 01:54 PM   #33
67cheby
67cheby
67cheby's Avatar
well i am about 99% sure now that i am going to go ahead and stretch them...as long as i can keep them looking right !! i did test fit them on a stock cab last night and did a little clearancing so no firewall modifications will be necessary !
Old 04-08-2011, 04:36 PM   #34
Jeebus
Jeebus's Avatar
yea its somewhere on this site.
I havent updated it in a while.
Taylor
Oops!
Old 04-08-2011, 08:51 PM   #35
jwalk
What was I thinking?
jwalk's Avatar
I voted over
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 04-09-2011, 09:25 AM   #36
67cheby
67cheby
67cheby's Avatar
thanks Justin.... anyone else need to vote , help a brother out !!
Old 04-11-2011, 10:21 AM   #37
67cheby
67cheby
67cheby's Avatar
ttt
Old 04-12-2011, 04:27 AM   #38
bucketObolts
bucketObolts's Avatar
Im running 28" now but after the summer shes going under the knife to fit 30
bucketObolts is offline   Reply With Quote
Old 04-13-2011, 12:28 AM   #39
stickelspeed
stickelspeed's Avatar
I voted over.
I'm running the same tire setup as old aux. The front tires are 255/40/20.
I'm running all the porterbuilt dropmember stuff and the bolt-on body drop.
I voted over as I assume the body drop is going to require it.
Hope this helps... Looking forward to seeing these... I need a set.
stickelspeed is offline   Reply With Quote
Old 04-13-2011, 09:07 AM   #40
67cheby
67cheby
67cheby's Avatar
How many of you think i should build 2 sets a low hump and a high hump ??
Old 04-13-2011, 09:48 AM   #41
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I say both
and over to cover a stock tire for us old school guys
Hottrucks is offline   Reply With Quote
Old 04-13-2011, 09:55 AM   #42
67cheby
67cheby
67cheby's Avatar
HOTTRUCKS.. i really think the low one would cover your wheels and tires, the low ones set about 1/2 inch under the very top of the fender , if you open you hood and set a 2x4 or straight edge from one fender to the other ,above the tires (when you are layed out) would your tires touch the 2x4 ?? here is a pic of what i am talking about
Old 04-13-2011, 10:01 AM   #43
Hottrucks
Hottrucks's Avatar
I need to cut the bottom off my X to get my truck to bottom out the suspention with Cupped LCA and 2 1/2" drop spindles the X is hitting first....I have avout an inch left but it would be close
I just want to roll and steer with out hitting anything but the ground...lol
Old 04-13-2011, 10:05 AM   #44
67cheby
67cheby
67cheby's Avatar
i understand
Old 04-13-2011, 10:23 AM   #45
Hottrucks
Hottrucks's Avatar
I do have to say thanx for asking tire "height" alot of guys dont get it....what about blower motor issues??? thats my big concern I love my heat and A/C
will these be glass??
Old 04-13-2011, 11:49 AM   #46
67cheby
67cheby
67cheby's Avatar
I understand and , the blower box ??? i deff think it will have to be modified !!
Old 04-15-2011, 06:12 PM   #47
67cheby
67cheby
67cheby's Avatar
ttt
Old 04-18-2011, 10:50 AM   #48
67cheby
67cheby
67cheby's Avatar
Ttt
Old 04-18-2011, 10:54 AM   #49
Hottrucks
Hottrucks's Avatar
I voted over as I assume the body drop is going to require it.:
not to highjack but what is this BOLT ON BODY DROP you speak of......Hmmmmm
Old 04-19-2011, 04:41 PM   #50
stickelspeed
Give Nathan a call at Porterbuilt.
On this site if you look at the Old Aux build thread you'll be able to get the general idea. Basically, its a complete set of new body mounts for the frame as well as modified/lowered sections for your framerails front and rear.
Once mine arrives I will upload pictures and progress.
