Old 04-24-2011, 11:04 AM   #101
flatbed51
flatbed51's Avatar
Re: My 50 roadster pickup build
Thanks Jim. Look forward to seeing more updates.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 04-24-2011, 04:04 PM   #102
oldman3
oldman3's Avatar
Well, since our Easter plans have changed, it will give me time to post some more pics. I had ordered a headlight kit from Hagan, it arrived and I decided to install it right away.
I cut the original lip down it the fender, as per instructions.
oldman3 is offline   Reply With Quote
Old 04-24-2011, 04:06 PM   #103
oldman3
oldman3's Avatar
Made sure to have the correct bucket for each side.
Old 04-24-2011, 04:08 PM   #104
oldman3
oldman3's Avatar
Not a very good picture, but all welded in and the coverput in place. Outer part of bucket lined up real nice with the fender. Real simply install. A little filler work and it will be good to go.
Old 04-24-2011, 04:09 PM   #105
oldman3
oldman3's Avatar
Welded up the center of hood, and all the old holes for emblems.
Old 04-24-2011, 04:14 PM   #106
oldman3
oldman3's Avatar
I had removed all the hinges and installed all new pins and bushings. Reinstalled the doors in place to check for fit. Made a difference in not sagging, doors also closed better.
As a side note: A trick I learned a long time ago, is to drill a 1/8" hole thru the hinge and body panel, tap the hole for a #8 or #10/32 machine screw and install it. Now each time you reinstall the door, install the main bolts (to hold door up) align this small hole with the screw, then tighten the main bolts. Door will be in the same position each and everytime.
Old 04-24-2011, 04:16 PM   #107
oldman3
oldman3's Avatar
Showing the installation of the Lokar shifter. (can't remember, but I think its the 6" arm) The white tape is what I wanted for angle of my console.
Old 04-24-2011, 04:20 PM   #108
oldman3
oldman3's Avatar
Pic 1 This is my first design, and just set in place.
Pic 2 After checking things out, I liked what I had, so I added additional pieces to hold shape. The machine screws on the side will attach to brackets welded to the floor.
Old 04-24-2011, 04:22 PM   #109
oldman3
oldman3's Avatar
These are the angle brackets, that the console will attach too. They have also been drilled and tapped for side screws to attach.
Old 04-24-2011, 04:25 PM   #110
oldman3
oldman3's Avatar
Pic 1 This is the front cover I bent to match the console, and cut hole for the shifter.
Pic 2 The back view shows that this will sit down inside the wood piece. The angle brackets have been drilled and tapped for machine screws.
Old 04-24-2011, 04:27 PM   #111
oldman3
oldman3's Avatar
Everything set in place. I will come back later to add radio, power window buttons and AC controls.
Old 04-24-2011, 04:29 PM   #112
oldman3
oldman3's Avatar
Need to take a short break, back in a few to post more pics.
Old 04-24-2011, 06:47 PM   #113
oldman3
oldman3's Avatar
OK, I'm back, full belly and all. Since I now have a digital camera I went to take a couple pics of my hinges, so you can see the screws I was talking about.
Pic 1 is the bottom hinge
Pic 2 is the top hinge (here you can also see the finish work on the dash)
Old 04-24-2011, 06:50 PM   #114
oldman3
oldman3's Avatar
Pic 1 Back on the pickup body. I have cut off the windshield header, and will cut off the 3" taped area for my chop.
Pic 2 Top piece that was removed.
Old 04-24-2011, 06:54 PM   #115
oldman3
oldman3's Avatar
I decided to make a cut thru the A pillar to just as it got to the body line (where stock windshield rubber goes). This allowed me to bend in the A pillar to align with the top piece. This way I was still able to maintain a nice round curve for the glass (part that's welded). Here I've clamped the top piece in place.
Old 04-24-2011, 06:59 PM   #116
oldman3
oldman3's Avatar
This is a critical part if you chop the windshield area.Make sure you check the angle of the A pillar on both sides (looking from the front). They must be the same angle. Also check the inside angle on the part that is leaning back. You must also check the glass area, make sure you maintain the height across for new class. I left my center steel bar in mine until I had everything welded solid, including the header cover plate. (This allowed me to push up the top until the measurements were the same, then clamp.) I removed the center strip later so I could V butt the glass.
Old 04-24-2011, 07:02 PM   #117
oldman3
oldman3's Avatar
Here my two pieces have been welded together and ground down, not to bad. Will do additional body work later. (Wanted to add, I welded small tabs inside the post and rosebud welded both sides and the back)
Old 04-24-2011, 07:03 PM   #118
oldman3
oldman3's Avatar
Here you can see the center strip in the windshield area, being held with a clamp.
Old 04-24-2011, 07:05 PM   #119
oldman3
oldman3's Avatar
I knew I wanted to remove the rectangular turn lights from the grill, so I ordered these from Watson's StreetWorks. I liked them being frenched and round to go with the headlights.
Old 04-24-2011, 07:06 PM   #120
oldman3
oldman3's Avatar
Here it is welded in place in the fender.
Old 04-24-2011, 07:08 PM   #121
oldman3
oldman3's Avatar
A front view, I know this makes it look like a GMC front end, but I like the round lights better. (same pic used above).
Old 04-24-2011, 07:12 PM   #122
oldman3
oldman3's Avatar
Now let's move to the rear section. This is the Hagen gas filler door I purchased for the left rear fender. Don't have other pictures on the install, but it was very simple to do (follow the instructions). Also not shown is the tube from filler to the tank. I made this out of 2" exhaust pipe elbows, with just a short piece of rubber hose to connect to the tank inlet.
Old 04-24-2011, 07:13 PM   #123
oldman3
oldman3's Avatar
Lid open ready for filling.
Old 04-24-2011, 07:14 PM   #124
oldman3
oldman3's Avatar
pic didn't show
Old 04-24-2011, 07:17 PM   #125
oldman3
oldman3's Avatar
Back to the doors at this point.
Pic 1 This is the passenger door bottom inside (drivers side was just as bad). The new patch panel I got from Classis Parts.
Pic 2 Old piece cut out and new piece installed.
