Old 04-26-2011, 11:32 PM   #201
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Pulled the floor off again to clean up the backside of the holes and prep it all for final assembly. Once it was ready, I bolted it onto the framerails and started laying down the wood. I like the fact that the mounting hardware will be completely hidden beneath the planks Still need to cut and drill for the bedsides and tubs, then it will all get tightened down...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-26-2011, 11:40 PM   #202
SCOTI
SCOTI's Avatar
Did you cut down your 'body pucks'? They look slightly shorter than my 3" ones (might just be how they appear in the monitor).
Wood looks good!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-26-2011, 11:57 PM   #203
gringoloco
A guy with a truck
gringoloco's Avatar
Wood looks good!
Yes, I took 1 1/8" out of them to accommodate the thickness of the wood stacked on top of the metal floor ribs. They are now 1 7/8" tall. Thanks for the comment- it still needs a little work, but should turn out nicely
-Chris
Old 04-27-2011, 12:03 AM   #204
VA72C10
VA72C10
VA72C10's Avatar
very nice!!!
Old 04-27-2011, 11:59 PM   #205
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by VA72C10 View Post
very nice!!!
Thanks! Getting there- slowly today...
Managed to get the bed floor bolted down tight after doing some more routing/trimming as some of the boards decided to warp on me What fun lying on my back running 50-plus nuts and washers onto the carriage bolts, all while snaking around the framerails, tank, and exhaust and finding creative ways to keep the bolts from spinning. Once everything was snug, I cut the wheelwells and drilled the perimeter mounting holes. Bed floor- DONE. Okay, still have to trim for the rear stakepockets...
My neighbor stopped by as I pulled the truck outside and commented on how nice the bed floor looked, and then asked if I was gonna treat the wood with anything. "Nope." Going for the 'weathered' look. Got an odd look. I'm sure he thinks I'm ruining it
Also, after making a huge mess with seam sealer and breaking my caulk gun, I installed some nutserts for the wheel tubs with a homemade 'tool'. Works pretty well, especially considering the actual installation tool is over $100. I woulda liked to have one, though, after about the third nutsert, as these things takes some 'oomph' to get them to crush. I am not looking forward to doing the other bedside...
-Chris
Old 04-28-2011, 12:04 AM   #206
VA72C10
VA72C10
VA72C10's Avatar
those are cool. Going to look factory to many people when done!
Old 04-28-2011, 09:13 AM   #207
67cheby
67cheby
67cheby's Avatar
nice work
67cheby is offline   Reply With Quote
Old 04-28-2011, 10:25 AM   #208
RatRod68
RatRod68's Avatar
Where did you get those nutserts? Those could be VERY usefull
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 04-28-2011, 11:36 PM   #209
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
agreed!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-28-2011, 11:41 PM   #210
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks- that's the idea. You guys will know, though...
Originally Posted by 67cheby View Post
nice work
Thanks!
Yeah, pretty cool little gadgets. Picked 'em up through Grainger.com. Should be able to get 'em at your local store or on Amazon.com as well.
-Chris
Old 04-28-2011, 11:42 PM   #211
mcbassin
Still Learning
mcbassin's Avatar
That bed floor looks awesome! Great idea with the nut serts. I may have to borrow that one myself. Nice!
Old 04-28-2011, 11:54 PM   #212
gringoloco
A guy with a truck
gringoloco's Avatar
Had some fun with the spray gun today after welding up the corner bracing and drilling holes for the rear cross-sill in its raised position. Sanded and scuffed the panels in preparation for primer- and then sprayed 'em. The primer looks grey in these pics, but is really black (this may be important later). The header panel is a truer representation of color than the bedsides; guess they were in the sun...
-Chris
Old 04-29-2011, 12:18 AM   #213
gringoloco
A guy with a truck
gringoloco's Avatar
Gave them some time to dry while at my daughter's tee-ball game, then scuffed 'em again so that the color would stick I shot two wet coats of the HRF and maaaan does it lay out nicely. It is very forgiving unless you are a complete bonehead, like I was...
I got in a rush (dumb thing to do while painting) and had the panels too close together, so that I had to squeeze between them while painting, causing me get too close to the header and run it :cry: Also had a leakage issue with the gun that got a few drips on the 'sides since they were laying flat. I'll have to decide if I can live with it when it dries completely, but will most likely be sanding and respraying the header- at least the front side- the back is just fine
All in all, I like this paint, and look forward to shooting more of it. I think it's gonna be cool In the pics, the jambs are mostly dry, as is the header, but the insides of the bedsides are still wet, hence the glossy-ness...
-Chris
Old 04-29-2011, 12:21 AM   #214
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by chevy2racr View Post
agreed!
These things are awesome, but a bit of a pain to install without the special tool. It can be done, but definitely eat your Wheaties!
Thanks a lot! This is why I put these things up here: in hopes that someone might get some entertainment or use out of it. Also don't mind the motivation
-Chris
Old 04-29-2011, 01:21 AM   #215
mcmlxix
Collector of Projects
mcmlxix's Avatar
I found them on eBay for less then the local stores or online....
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Rich
1972 K5 Blazer CST Click HERE
Old 04-29-2011, 11:50 AM   #216
yote1234
yote1234's Avatar
very nice !!!! keep up the good work.
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 05-02-2011, 11:41 PM   #217
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! Trying to keep the momentum- stuff just keeps getting in the way- stupid responsibilities...
I did manage to make a little progress by popping out the back glass using the extension cord trick and getting some primer on the back of the cab and paint on the wheeltubs. I didn't paint the cab, as it will get wetsanded before color...
It is killing me to not be perfectly bodyworking this truck before paint. I keep wanting to do it 'right'. I think the technique will pay off though, as the reward for not having worried about the details now is not sweating parking it at Home Depot- or loading it with the junk I buy there. Just might end up with a sweet faux-tina, too
-Chris
Old 05-03-2011, 01:17 AM   #218
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks good!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-03-2011, 08:48 AM   #219
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Jacfourteen View Post
Looks good!
Thanks! I hope to actually have a complete truck again soon...
-Chris
Old 05-03-2011, 09:03 AM   #220
68Driver
68Driver's Avatar
Howdy,
My project is down to the frame right now and I'm within a month or so of pulling the trigger on whether to paint or powder?? How did you like the powder coat when you got your parts back? It looks very very nice. The word on the street is that powder is the way to go?? What are your thoughts? THanks..
68Driver is offline   Reply With Quote
Old 05-03-2011, 09:24 AM   #221
67cheby
67cheby
67cheby's Avatar
Looking good
Old 05-03-2011, 06:43 PM   #222
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 68Driver View Post
Howdy,
I like the powder for it's durability, buuuuuut, it is more expensive and impossible to touch up if you do manage to scratch or chip it. If I were doing a frame-off, I would go powder. Personal preference
Looking good
Thanks! We're getting there...
-Chris
Old 05-03-2011, 07:29 PM   #223
bosco200
bosco200's Avatar
Thank god you changed the bed that was my biggest worry,
bosco200 is offline   Reply With Quote
Old 05-03-2011, 08:59 PM   #224
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice progress GL! Love the floor/bed mods.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-03-2011, 10:32 PM   #225
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- me too! It was one of the first things to go...
Thanks! Hope to have it back together soon
-Chris
