Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 88-98
Old 02-08-2011, 01:54 PM   #1
scotts62
One day...
scotts62's Avatar
Lightbulb 88-98 FAQ's "Is your truck running weird? Check here it could help"
Post your threads here for the new 88-98 FAQ post which will be a separate sticky when complete.
Please make sure that the pics are uploaded to this sites gallery when used here to ensure the URLs are still there later for when we are looking through this thread for help, Thanks.
Scott
93 crew cab build
Project 62
Old 02-08-2011, 05:14 PM   #2
scotts62
One day...
scotts62's Avatar
Re: 88-98 FAQ's
Ill add more when i find some good ones to help
High idle problems
http://67-72chevytrucks.com/vboard/s...d.php?t=439984
EGR identification (thanks Chevytech)
http://shbox.com/1/EGR_ID.jpg
Scott
93 crew cab build
Project 62
Old 02-09-2011, 11:21 AM   #3
ChevyTech
Re: 88-98 FAQ's
Scott – dig through these and see which ones you want.
I will work on this more later.
Running Rich, or acts like no choke = Coolant sensor testing:
http://67-72chevytrucks.com/vboard/s...d.php?t=322811
http://67-72chevytrucks.com/vboard/s...d.php?t=379142
Tighten up Tilt column links;
On C/K trucks in 1995 they went to a “new” style column.
If your truck is a 1994 or older the following information should help.
Here are some steering column sites with photos that tell how to repair loose tilt columns. The photos should be helpful.
http://www.fieros.de/en/articles/steering.html
http://elcaminocentral.com/article95.html
Looks like on this site he did the quick fix and did not take it apart far enough to tighten all four fasteners.
http://www.chevyasylum.com/column/tiltcol.html
Exploded View of a tilt column.
http://www.nastyz28.com/tech/e-tiltcol.html
Older car but good photos
http://buickperformance.com/tiltstee...lumnwobble.htm
Tilt column lock plate removal;
http://67-72chevytrucks.com/vboard/s...ht=tilt+column
Fuel pressure testing – split hose in tank:
http://67-72chevytrucks.com/vboard/s...d.php?t=375132
Set timing wire connector for 1988- 1993 C/K pickup trucks illustration:
http://67-72chevytrucks.com/vboard/a...1&d=1251120221
Old 02-09-2011, 01:04 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 88-98 FAQ's
This is gonna be a great help to those who seek help, without asking "where, who, etc.," before doing a search for the help they need. There's a lot of information on here that people can access, if they will just take the time to utilize the already available resources.
Member Nr. 2770
Old 02-09-2011, 01:54 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: 88-98 FAQ's
How-To: 88-91 speedometer calibration 25085515 91' tach upgrade
tommie is offline   Reply With Quote
Old 02-09-2011, 02:37 PM   #6
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: 88-98 FAQ's
Cleaning evap core for better a/c function
Edit: Also wanted to say that an 88-98 FAQ section is a terrific idea -- it seems like every day there's somebody with EGR/IAC/ECTsensor problems. The FAQ section should be subtitled "Is your truck running weird? Check here first!"
Old 02-09-2011, 07:08 PM   #7
ChevyTech
Re: 88-98 FAQ's
1991 & later TBI V8 Oil pressure sending unit location, engine wiring & sensors illustration:
Also shows ground on back of passenger cylinder head.
http://autorepair.about.com/library/...bl283a-lib.htm
TBI V8 Knock sensor location photo
from “PCMCOBRA”, from one of the truck boards.
http://i114.photobucket.com/albums/n...010Small-1.jpg
Dash Brake indicator on or blinking = RWAL problems
Here are two of the better threads
http://67-72chevytrucks.com/vboard/s...d.php?t=302690
http://67-72chevytrucks.com/vboard/s...d.php?t=399153
TBI parts & sensor photos
EGR (Exhaust Gas Recirculation) valve
EGR solenoid
IAC (Idle Air Control)
MAP (Manifold Absolute Pressure) sensor
TPS (Throttle Position Sensor)
All labeled in photo of 1993 Silverado:
http://67-72chevytrucks.com/vboard/a...1&d=1278787232
Old 02-09-2011, 08:58 PM   #8
scotts62
One day...
scotts62's Avatar
Re: 88-98 FAQ's
HOW TO: Manual locks and windows to power conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=445732
Scott
93 crew cab build
Project 62
Old 02-10-2011, 09:39 PM   #9
BHBurban
BHBurban's Avatar
Re: 88-98 FAQ's
Bucket seat options for 88-98's
http://67-72chevytrucks.com/vboard/s...38#post4476938
"94 Suburban '89 Dually '00 Tahoe 88 shortbox
BHBurban is offline   Reply With Quote
