05-28-2011, 11:01 AM | #1301 |
Sofa King Crazy!!
Re: 1967 C10 Custom Big Window
Since I have bags on the truck and no alignment yet, will that still affect it?
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 05-28-2011 at 11:02 AM. |
05-28-2011, 11:08 AM | #1302 | |
Still plays with trucks
I would install the bar with it aired up to be in the middle of your ride height range so the end of the sway bar has room to slide for both going up and down in ride height without it pulling out of the bushing.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
05-28-2011, 11:15 AM | #1303 | |
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 05-28-2011 at 11:21 AM. |
05-28-2011, 11:33 AM | #1304 | |
Poly takes a special grease but rubber you can use a silicone spray or even WD40 to get them assembled. I've never tried baby powder.
05-28-2011, 01:32 PM | #1305 |
VA72C10
That was a good score, looks good in pc, and will help the handling!!!
Looking for a 67-72 swb or blazer project in or around VA. |
05-29-2011, 03:58 PM | #1306 |
Truck looks nice!! Something a little different nice LWB. I live over on the eastside of town in the Baytown area. I have several friends that live out in the Tomball/Cypress area. I'm going to check out one of those niffty fiffty shows soon. I have a SWB GMC 70 model and plan on running the same basic suspension setup as you. My question is did you have to do any kind of modifications to your inner fender wells front or back? The fronts look untouched.
05-29-2011, 07:44 PM | #1307 | |||
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
05-29-2011, 08:19 PM | #1308 |
Awsome my first piece of advice. I will definately keep that in mind when I get to that point. I have actually already bought a set of wheels and tires from a friend. the wheels are 20X8.5 front and 20X10 rear. Hear is my wheels on my buddies truck.
05-29-2011, 08:48 PM | #1309 |
My little buddie at work that is helping my green ass out sugested a watts link. What do you think?
05-29-2011, 09:51 PM | #1310 |
Sofa King Crazy!!
That's a sweet truck! I would research it here on the board in the suspension area first then make a well educated decision. A long bed is gonna be a little different from the short of course. I have yet to decide on what to do with mine, but I don't wanna run the panhard bar for sure.
05-30-2011, 09:31 AM | #1311 |
low n' slo
my panhard bar is run from the driver side frame to passenger side trailing arm, its a lot less movement than the stock ones. the longer the bar, the less movement you have.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-30-2011, 02:29 PM | #1312 |
Sofa King Crazy!!
I will have to check into mounting mine on the trailing arm then. My panhard bar is adjustable so maybe I can make it extend far enough or put another end on it to adjust it futher. Thanks Kev!
05-30-2011, 03:31 PM | #1313 |
low n' slo
np! the one i bought was extendable too but cpp makes 3 sizes i think, and i got the shortest one lol. i just cut it in half, welded a 1" thick bar in between in the length that i needed. works fine!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 05-30-2011 at 03:31 PM. |
05-30-2011, 08:20 PM | #1314 |
Sofa King Crazy!!
Cool! Thanks Kev. Another little project I can do while waiting on my engine.
05-30-2011, 09:34 PM | #1315 |
low n' slo
cool, post some progress! just dont do what i have been doing while waiting on buying a compressor...i shaved the firewall (didnt plan on it), shaved up the mirror holes (didnt plan on it), and now about to move my bags on the axle (once again, didnt plan on it) lol.
05-30-2011, 09:50 PM | #1316 | |
Sofa King Crazy!!
06-04-2011, 03:27 PM | #1317 | |
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
06-05-2011, 05:59 PM | #1318 |
Sofa King Crazy!!
Yeah, keep rubbin it in. One day mine will be there.......again.
06-08-2011, 09:04 PM | #1319 |
Sofa King Crazy!!
Talked with the engine shop today..........he actually did something. He sprayed the engine with brake cleaner where the crack is supposed to be and could not get anything to come through. He said the timing chain cover is coming off tomorrow so he can better see the suspect area and then weld as needed. I asked when I could get it and he said the end of this week or sometime next week. Yep, I can live with that.
06-08-2011, 10:03 PM | #1320 |
awesome to hear Slick. hope he comes through with it. although I think he could have done more work then just sprayed it with cleaner and looked at it in one day. IMO any how.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 06-08-2011 at 10:03 PM. |
06-09-2011, 09:40 AM | #1321 |
Sofa King Crazy!!
Yep.......what a turd.
06-09-2011, 10:00 AM | #1322 |
Hope he makes sure to get all the brake cleaner out of the crack before welding on it. Makes some nasty stuff if theres any left and it gets heated. I think its like Phosgene gas. Used during the 1st war to gas the troops. Good luck on the engine. The trucks awesome.
06-09-2011, 01:08 PM | #1323 | |
Sofa King Crazy!!
06-09-2011, 03:46 PM | #1325 |
Sofa King Crazy!!
I hate to bring it out without the bed and the interior done, but it might just happen before the end of the Niftee 50ees 2011 season.
Tags |
1967, custom, lwb |
