LS with stock gauges/tach
I have a 1970 short box with stock gauges. Is anyone running stock gauges/tach with their LS swap?
#2 | |
69' Chevy Stepside
![]() Join Date: Mar 2008
Re: LS with stock gauges/tach
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
i too am running Cable X ($300 shipped from Herron Performance).
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
You can avoid all that mess if you are using a 4l60e or a 4l80e you can just find a electric speedo out of a 91 burb. I have 3 if you need one. and hook that up. then you can adjust the speedo through the pcm for gears and tire changes
I LIKE TRUCKS 1986 GMC Suburban Build Build link 1982 Chevy SWB 2wd Scottsdale, Build Link Sold ![]() 1987 Jimmy Build, Project Cheap A$$ Build Link |
This sounds interesting. any pics? Is it a difficult swap? I may want a speedo from you.
It is an easy swap, you just follow the circuts around the printed board and rewire to the same as your old cluster. then hook the vss from the pcm to your speedo I have the pigtail connector for the electric speedo as well so you just hook your factory wires to the new harness where they need to go
#7 | ||
I can not believe I missed that, I'm sorry for the confusion. I have been reading so much of this forum that I must have confused myself :S
