Old 08-13-2011, 10:00 PM   #1
Joe Blaze
'71 Blazer, 2" lift, steering questions
My Tuff Country 2 inch Lift Kit is on its way for my '71 Blazer. I will be running 32x11.5 Cooper Discoverer STTs on it. Can anyone advise if I need to get a dropped Pitman arm, or an adjustable drag link, etc...?
This is what I have on there now, i dont know if it is dropped or not.
Since I have the solid, non-adjustable drag link, do I need to get one of these?
http://www.jackit.com/store/supercart.cgi?s=jac_1001
And would any of the other crap on this page be necessary/useful for me?
thanks.
Joe Blaze is offline   Reply With Quote
Old 08-13-2011, 10:19 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: '71 Blazer, 2" lift, steering questions
You can get away with just an adjustable draglink with a 2" lift. The draglink needs to be close to level with the steering arm.
You do not have a dropped pitman, that is a stock one.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 08-14-2011, 11:29 AM   #3
Joe Blaze
Can anyone advise a source of a reliable quality adjustable drag ling for this project?
Old 08-14-2011, 01:07 PM   #4
bigbadchev72
People know me
Just go to your auto parts store, They will have both ends and the adjuster sleeve. Might have to order it for a 73' or so blazer. Not sure if your non adjustable one is stock for that year.
Mine came with an adjustable one
Old 08-14-2011, 08:04 PM   #5
my90k5
72 K/5 Junkie
my90k5's Avatar
Can't wait to see the 2" with 32's. Be sure to post some before and after pics. I'm doing a 2" soon.
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 08-14-2011, 08:48 PM   #6
AlaskaMatt
AlaskaMatt's Avatar
You should be fine with the adjustable drag link. That's what I have with 2.5 lift. I had a raised steering arm for the 4 inch lift previously in the truck. When I dropped it down man it had BAD bump steer. Went back to the stock are arm (with adjustable drag link) and all was good.
Thanks,
Matt
My Website
AlaskaMatt is offline   Reply With Quote
Old 08-14-2011, 10:33 PM   #7
stilesjimmy
would you mind getting a measurement from the inside of the spring to the nub in the middle? I have some springs and was wondering if they will work on my blazer. thanks,
stilesjimmy is offline   Reply With Quote
Old 08-15-2011, 12:19 AM   #8
Joe Blaze
Here is the page from LMC. I ordered parts # 1 through #5 today. My local guy said the three drag link parts were available, and pretty standard used for many model years, but the tie rod ends (#1 & #2 in diagram below) were not available anymore. So i ordered online
Old 07-11-2012, 04:41 PM   #9
40what
Good posts however older... anyone have any follow up on this topic? I am looking to do a 2 to 3 inch lift myself.
Where can I get an affordable full kit? I've been all over the net. Jackit is expensive while rough country is reasonable. However, RC only offers a minimum of 4"
I'd love to see pics of the 2.5's including the pitman arm area.
Thanks!!
40what is offline   Reply With Quote
Old 07-11-2012, 05:20 PM   #10
1972CST
1972CST's Avatar
TC soft rides are the way to go on a budget. I have the 2" all spring kit and it does the job.
1972CST is offline   Reply With Quote
Old 07-13-2012, 10:05 AM   #11
40what
72CTS,
Did you have to do any mods? Brake lines? Tranny drop? Drag link?
Do you have pics?
Thanks,
Mike
Old 07-13-2012, 11:42 AM   #12
SeventyOne
On a 2" lift I would think all you need to do is get the adj. drag link.
I would check the brake line length too but they might be ok for such a mild lift.
Drivelines/trans/etc should also be fine.
SeventyOne is offline   Reply With Quote
Old 07-14-2012, 12:03 PM   #13
1972CST
1972CST's Avatar
Originally Posted by 40what View Post
72CTS,
Do you have pics?
Thanks,
Mike
Sounds like Seventy One hit the nail on the head. I dont have any other mods, just the new springs and shocks. I did add a zero rate to the rear to level it up (not installed in pic). I am running 33x12.50's (actually measure 32" tall). I used the stock drag link, just adjusted to re-center stearing wheel.
