What should I check?
This is in GMC S15 truck why both wipers stops working after a few minutes of use? it stop suddenly and than after a while starts on its own??? what can be the problem and solution? Last edited by vikasintl; 09-28-2011 at 01:10 PM. |
Re: What can be the reason why windshield wipers stops working after few minutes?
Does the truck have intermediat(sp?) wipers?? If so the control module for the them could be bad. Or your wiper motor is on its way out. I've seen motors work until they warm up then quit. cool down, take off again. Thats my .02 worth
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#3 | |
![]() Join Date: Sep 2005
![]() it could also have a bad pulse board
BAD BOW-Silverado XST
The infamous bad circuit board problem!! Easy fix and you can do it yourself!!
blood type; Retumbo
your truck is suicidal and wants you to not see the tree before it slams head-on into it. have a nice man to truck talk with it over a quart of 5w30. I can give you talk advice if you tell me how old he is.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
^haha!
Yeah depending on the year, its a very common problem. Pull the circuit board in the wiper motor housing out and resolder the larger connections. The weight of the harness bouncing around is/was enough to break the crappy cold solder joints. Posted via Mobile Device |
mine does that too.
84 C10 lwb 89 S15 Jimmy 4x4 |
Tags |
windshield, wiper, wiper arms, wiper motor |
