Old 09-30-2011, 12:51 AM   #1
mo1968
mo1968's Avatar
quadrajet/ 700r4
Does a quadrajet carb need geometry bracketry of any kind when installing a 700r4? I have numerious oem gm brackets and 2 differant 700r4 cables. Cant get the 700r4 shifting correctly. Am I not setting up the adjustment propertly or is it impossible to setup with just the items i have? If i have a kickdown bracket and cable from the same vehicle, would it then work? Do I need geometry brackets? PLEASE and THANK YOU
mo1968 is offline   Reply With Quote
Old 09-30-2011, 07:45 AM   #2
MARKDTN
Re: quadrajet/ 700r4
Just get a bracket and cable for that application. Trucks, Vans, and Caprices from '83-88 all had SB with Q-jet and 700R4 as an option.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-30-2011, 04:16 PM   #3
mo1968
mo1968's Avatar
That was easy. Thank you.
700r4, bracket, quadrajet
