Moderator
![]() Join Date: Jun 2008
Adding an AM/FM Decal
I recently acquired an early model van AM/FM radio. It has the Delco inscribed on the lens, which made me think it was an original truck radio. I later found out that it wasn't. The letting on the dial drum was white and a different font. I purchased some reproduction truck AM/FM drum decals to install. However, I could not find any write-up for installing any. So, being the do-it-your-selfer, I decided to do my own write-up.
So, here it goes... 1. Remove the 5 sheet metal screws on the top of the radio.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 04:57 AM. |
Moderator
Re: Adding an AM/FM Decal
2. Remove the top cover. Be careful not too pull to hard so you don't damage the radio light connection at the circuit board.
70 Longhorn CST Build Adding an AM/FM Decal |
Moderator
3. Remove the light bulb from the light housing. Then unclip the light housing from the top radio plate. This will allow you access into the radio to unscrew the two sheet metal screws that fasten the dial drum housing (see step #5).
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 04:19 AM. |
Moderator
4. Next, remove the front face plate. Remove the flat nuts on the radio shafts. Then, remove the four sheet metal screws holding down the face plate, remove the plate.
Moderator
5. Looking down into the radio as it lays flat right side up, you will see two sheet metal screws-one on the left side, and one on the right side of the radio dial drum housing. Carefully remove each of these screws. You will need to move the radio station from one left, then to the right in orider to allow enough room to access the screws. Be careful not to let the screws fall into the radio. The sheet metal screw on the left has a skinny, flat piece of metal that rests on the dial indicator. Study its resting position before removing so you are confident when it comes time to reinstall the screws.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 04:22 AM. |
Moderator
6. From the front face of the radio, carefully remove the dial drum housing. BE CAREFUL as to NOT stress the dial adjustment string...remember, it's 40+ years old and likely to be on the brittle side. Also be careful not to scratch the orange paint on the back side of the indicator needle as you remove the dial drum housing.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 04:23 AM. |
Moderator
7. Clean the AM/FM drum with water and a Q-Tip. I did this step out of order. It will actually be easier to clean once you remove the dial drum from its housing.
this is a nice thread. What is the small metal piece on the left side for? Sorry, just realized I should have waited until your steps where done to comment.
Moderator
8. Remove the dial drum from its housing: In order to do this without causing any damage, you will have to spin the dial inside of the housing until the little plastic tab on the right end of the plast drum lines up with the hole on the right side of the houseing (shown in this picture). Shift the drum so the little pin slips into the hole. This will allow you carefully lift the left side of the drum up and out of the housing. Be careful to study the position of the tension spring on the right side. Note the direction that it sits on the its pin.
Moderator
9. Next, you will need to prepare your decal. They are printed with a bit of extra black area that you will need to cut off to fit properly. Take some measurements off of your original dial and mark your decal for cutting. Once the decal is cut, remove the backing paper and carefull apply it to the drum. Be careful when applying it so you do not get any air bubbles.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 03:44 PM. |
Moderator
10. Once the decal is firmly in place, reverse the order of removal. Take your time. Be sure to remember when reinstalling the face plate that you line up the AM/FM switch lever with the indicator shaft so it will flip to AM/FM when you move the lever.
Once it's all back together, enjoy your new truck AM/FM radio ![]() I hope this write-up helps. -Richard
Moderator
No problem, Brian. I am not sure what that piece of metal is for. It's either for tesion on the AM/FM switch so it is not sloppy, or to keep it from traveling too far in a given direction. I'm just guessing, though.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 01-21-2012 at 05:22 AM. |
Thanks for the great how-to and pictorial. Hope the moderators make it a sticky.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
![]() Join Date: Nov 2007
Nice Job Richard
72 C20 Longbed 05 1500 Z71 |
#15 |
Nice job x 2.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
#16 |
Cool write up !!! Hope this helps with my radio. One day I looked down and the dial was just missing. I hope it is an easy fix. I bet it would be difficult to find parts.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#17 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Thanks for sharing, you are very talented...I read your build thread too.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#18 |
![]() Join Date: Apr 2010
#19 |
Is that an easy fix??? The radio worked fine but now I get nothing.
#20 |
VA72C10
![]() Join Date: Mar 2008
Nice writeup! Recommended for FAQ!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#21 | |||
Moderator
Thank you Jorge! Thanks! Quote:
![]() Thank you, Jonathan!
#22 |
Waiting for Paul to Open Safe
Awesome write up Richard a copy can now be found in the FAQ area http://67-72chevytrucks.com/vboard/s...d.php?t=509765 Thanks!
#23 | |
Moderator
-Richard
