#3826 |
Re: Project Vitamin C-10
It has been my experience in every vehicle I have driven, Civilian and Military, that the lights stop flashing when you have the 4ways on, and your turn signal indicators will stay lit as well. If after you charge your battery and check your 4ways again, and they only flash 7-8 times and stop I suggest reaching in and feeling your 4way controler/flasher see if it is uncommonly warm to the touch.
Same thing if your head light switch seems twitchy. These things tend to stop working when they get too hot due to an internal short IIRC.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#3827 |
#3828 | |
![]() Quote:
My 1965 C10 does this... flashers on and flashing-flashing, if I hit the brake the blinker indicators on the dash(stock 1965 dash with gauges) go solid. However, my steering column is a 1971... and I wired in the flasher unit after I bought the truck, when I realized it was possible. I was discussing some of this stuff on another old truck board and a fella explained it to me. dunno if that helps you or not, but that is what mine do as well. -W |
#3829 | |||||
1 thing at a time is progress.
I hope to get the apprasial this week. Quote:
![]() Like I mentioned above I did put a charge on the battery. It didn't seem low judging by the charger, but the flashers are working good now. The turn signals don't do anything. The only thing that I have noticed is with the brakes on and when I turn on a turn signal, the brake light goes out. Remember nothing is hooked up on the front as far as lights go. Today I installed the wiper motor and drive. I hot wired the wipers to make sure everything moves like it should. No abnormal noises. Installed the cowl panel and hood to cowl seal. Hooked up the headlight relays to the battery. Got the fan relay all hooked up, but the ign wire to the temp sensor for the relay. Trying to figure out the best point to pull power from. I did hot wire the fan to make sure I had the polarity correct. It sure is quiet.
Alan
Philippians 2:14-16 |
#3830 |
Forgot to post this. Here is a thread about truck prices at Barrett-Jackson.
This one went for $32,450 with fees included. I noticed it has a points dizzy, power drum brakes, no AC, no fan shroud, not a custom cab and I believe a small window. I'll show the appraiser when he comes out. ![]()
Alan
#3831 | |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#3832 |
I agree, the wheels are hidious,, 5 spoke Cragers would have been much better..
#3833 | ||
that is one of those days when you cannot seem to shut the engine off fast enough!! LOL By comparison, quiet is GOOD !!
#3834 |
did any body notice the body work, that drivers door looks like a bowl and I'm sure it is not a reflection, I think Alan's should appraise for much more just based on the level of quality of workman ship
#3835 |
Rollin' Old Skool
just a cookie cutter cast chrome wheel made by Panther Wheels...not worthy of being on a nice, classic truck IMO
#3836 |
I've been doing a lot of catching up recently with your thread. I started on page 23 a few weeks ago, and have read a few pages a night, until I finally caught up. Your truck looks amazing and I can't wait to see what it appraises for. You do great work and have got me going again on my '65. Which brings me to a question. I'm pricing what it would cost for someone to blast the interior and exterior of my cab and both doors...nothing else. I've had a company quote me $750 and I'm waiting from another company to get back with me. Does $750 seem like a reasonable price?
#3837 |
allen, trucks coming along nicely, yours is sure alot nicer than the green one at barrett jackson so it should appraise for at least a half million
#3838 |
Yes sarge, when I started my 57 had the fan on the engine.. srarted ran fine.. let idle for a while back out on drive way revved up the motor and put a perfect circle in the brand new alumiun raditor when the blades flexed with additional RPMs. 3 gallone of anti freeze on the ground and a $150 raditor shot to He##$$%^&&*(). Called summit ordered new efan and new raditor. 10 years ago and no problems since. at least with the raditor. LOL
#3839 | ||||||||
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() No updates to post, but I will raise the question again. Like I mentioned above I did put a charge on the battery. It didn't seem low judging by the charger, but the flashers are working good now. The turn signals don't do anything. The only thing that I have noticed is with the brakes on and when I turn on a turn signal, the brake light goes out. Remember nothing is hooked up on the front as far as lights go.
Alan
#3840 |
#3841 | |
![]() Posted via Mobile Device
Alan
#3842 |
I was going to mention a digital flasher relay too, but the dash lights probably would not flash if you didnt already have one
#3843 | |
I hooked up a bulb for the front turn signal and the turn signals work. I did both circuits. High beam indicator is staying on, but I will deal with that once the headlights are in.
Alan
#3844 |
Good work Alan we all need a 2/4 upside the head ever once in a while.. LOL
#3845 | |
The voltage is so low on led's that they don't generally draw enough amps to pull a regular analog flasher You are running rear LED's right? at least I thought you were |
#3846 | ||
![]() Quote:
Alan
#3847 |
Maybe your new fuse block and harness already had a digital/electronic flasher installed I think they will work with both types of systems but don't quote me on that
#3848 |
It appraised at 60K.
Alan
#3849 |
Rollin' Old Skool
Cha-ching!!!
#3850 |
Daring to be Different
Your going to donate it????
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
