05-03-2012, 11:01 AM | #1 |
Stirrer of the Pot
60-66 stereo options
I'm not seeing much in terms of bass. Anyone have a good sub install in a 60-66? There is such limited space, what are you guys running?
also having no door locks... I've been tempted to try to hide the CD player under the dash and blankout/shave the current stereo slot. what have you guys done? |
05-03-2012, 06:18 PM | #2 |
Re: 60-66 stereo options
I moved the gas tank out, now there's plenty of room for an amp and custom MDF sub box.
With the gas tank still in the cab, about the only way is to build one or two custom sized MDF board boxes to fit under the seats.
292 + TKO500 |
05-03-2012, 07:47 PM | #3 |
someone on here put a bass tube next to the seat on passenger side.said there was plenty of room? have you checked in the stereo section?
05-03-2012, 09:04 PM | #4 |
Junior Member
I was able to fit a 8 in bazooka tube in the corner of the cab, behinde the seat next to the gas tank
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
05-03-2012, 10:15 PM | #5 |
If your tank is relocated there is tons of room for two 10s or two 12s in shallow boxes
I personally have two 10s behind the seat powered by 1200 watts |
05-03-2012, 11:36 PM | #6 |
Stirrer of the Pot
ozzy can I see pics of your setup, subs and amp? I am moving the tank to under bed. hell, in be if I have to, but its going. I was hoping for maybe 2 x 10's if possible but it still looks shallow even with tank pulled....
would love to see both, decks, as well as amp/sub configurations. and yea, I looked a lot in the stereo section but didn't see what I really wanted to see. I'm sure someone has built something badass?? |
05-03-2012, 11:44 PM | #7 |
I used a cheaper Pioneer deck, a good amp with an eq under my seat, and a 8 inch bass tube on the passenger side behind the seat.... great sound.
1966 Chevy C-10 350 Engine 700R4 |
05-03-2012, 11:49 PM | #8 |
Currently my Cab is gutted for restoration and rust repair but I do have a picture.
I was 16 when I installed this and nothing was secured except for the amp, being young and dumb I screwed it into the rear cab sheet metal...... Guess what I'm doing now? Filling holes! The subs must be made for a low cubic ft shallow box for this setup to work. These boxes also had some horn tweeters mounted ontop of them, I'd recommend a ported box being so small Been a while but now that I look at them I think they might be 8's, but I could have sworn they were 10s |
06-06-2012, 09:13 PM | #9 |
After seeing some of these sound set ups now I know why you youngsters always say HUH? Damn those things gotta be lound inside that cab.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
06-06-2012, 10:16 PM | #10 |
Stirrer of the Pot
what?
07-11-2012, 05:52 PM | #11 |
if you moved your tank...
this is my sub/amp/battery enclosure. it's in a 58 but easily made to fit any truck cab
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-12-2012, 01:25 PM | #12 |
Mine should only hit about 130db. That's only 5db louder than a rock concert.
I'm 40 now, when I was younger, it was more like 125db, need to make up for the loss over the years.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
07-12-2012, 04:40 PM | #13 |
Stirrer of the Pot
you have any pics of your setup Jimmy?
I have tough decisions to make. longterm i want to bag the truck... so I feel like I should wait till I bag it to move the gas tank, but at the same time, I want my stereo NOW! lol |
07-16-2012, 03:45 PM | #14 |
"Easily" !?!?!?!
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
07-18-2012, 12:18 PM | #15 |
07-20-2012, 10:39 AM | #16 |
In my 63, I made a box to fit in between the firewall and the seat with a single 10" sub firing upward on the transmission tunnel.
07-05-2013, 06:08 AM | #17 |
I have a shallow 12, in a downfiring box that fit under my bench. I pulled the adj rod for some extra space. You cant see any of it. deck is in the glovy, 6x9s are on the floor right up front.
