Old 07-23-2012, 01:39 AM   #1
blazerboy_4life
70Custom10
Lets see your Short bed 3/4 tons!
Anybody have a short box 3/4 ton TWO wheel drive? Im interested in pics of both but Im currently building a short box step side 6 lug half ton and I was thinking about picking up the stuff to convert over to a 3/4 ton. I found everything at a local salvage yard. They want $125 for the rear end and $150 for all front end components. Seems like a good deal?
Anyway...Bring On The Pics!
blazerboy_4life is offline   Reply With Quote
Old 07-23-2012, 01:46 AM   #2
blazerboy_4life
70Custom10
Re: Lets see your Short bed 3/4 tons!
Id really love to see a lowered short bed step side 3/4 ton if theres any out there.
Old 07-23-2012, 07:40 AM   #3
Good luck. I know of one. Most people wonder,"why?",when the topic comes up. 4wd is another story. I have a 3/4t Jimmy and wish it was 1t. But,that's because of the use of a 4wd,the bigger the axle the stringer...especially for bigger tires.
Old 07-23-2012, 09:51 AM   #4
blazerboy_4life
70Custom10
I say isnt that what building a hot rod is all about?... The Why not... Lol I just like the way the 8 lugs look and the parts are cheap. I currently have drums up front and these are discs. Plus I might be bartering my way into a Vortec 8.1 and i think it might be nice to have the extra strength for the extra power...
Old 07-23-2012, 10:02 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Go for it! One of my regrets was not buying a beautiful, healthy built '72 SWB 4x4 with FF 8-lug axles back in 1977.
At the time, I didn't know it wasn't OEM....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-23-2012, 11:56 AM   #6
BurnoutNova
BurnoutNova's Avatar
A 12 bolt should be plenty strong, or a 9" ford would be best. The biggest problem is tires. I have an 86 SWB K10 that I did a 3/4 ton axle swap and it is tough to find good deals on tires. I got lucky an found some on craigslist, but that doesnt happen whenever I really need something.
BurnoutNova is offline   Reply With Quote
Old 07-23-2012, 07:50 PM   #7
blazerboy_4life
70Custom10
Really? Nobody has a pic of these??
Maybe I SOULD build one so I will be the first? What is is that makes the ford 9" superior to anything GM anyway?
Old 07-23-2012, 08:28 PM   #8
terry b
terry b's Avatar
Ford was smart and did't use C clip's in it's nine inch.
terry b is offline   Reply With Quote
Old 07-23-2012, 10:02 PM   #9
Ford 9"s are power robbers. No one seems to mention that. A Dana 60 is a better rear,if you ask me. You can put c-clip eliminators in 12-bolts,as well as all sorts of goodies.
Old 07-24-2012, 12:35 AM   #10
bigblockhemi
i have one its a 72 3/4 ton i cut down to a short bed but i cant post a pic :/
bigblockhemi is offline   Reply With Quote
Old 07-24-2012, 01:06 AM   #11
CG
BlahBlahBlah
I think the reason its not done a lot is because 3/4 tons are already a bit rough riding and when you shorten em up it makes rougher.
There are quite a few long box 3/4 trucks lowered and looking nice on the board. Should look just as nice if they were shorties.
Old 07-24-2012, 09:50 AM   #12
blazerboy_4life
70Custom10
Can you pm or email some pics? I would even take a text at this point. Lol
Im sure it will look as good if not better than a long box. Im just a visual person and need an image to get my mind moving better.
This 3/4 ton set up is going on a half ton frame and springs (eventually bags) so it shouldnt ride any different than a regular half ton I wouldnt think. Would it?
Old 07-24-2012, 10:36 AM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The only apparent ride difference would be caused by the heavier axle/suspension components. Increased unsprung weight will make the shocks work harder and will affect ride quality somewhat -- though maybe not enough to matter, or even enough to be noticeable.
- Mike -
RIP El Jay
Old 07-27-2012, 08:37 PM   #14
bigblockhemi
sure i have lots of pics u can email me bighemizuk@yahoo.com and ill send u some asap
Old 07-28-2012, 09:57 PM   #15
Boog
laying low
Boog's Avatar
The 3/4 ton springs are stiffer also. Harsher ride with shorter wheelbase and reduced weight. I suppose you could stick with 1/2 ton springs though.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-11-2012, 09:22 PM   #16
blazerboy_4life
70Custom10
Still nobody has any pics??
Old 08-12-2012, 10:04 AM   #17
obijuan
pretend you added two more lug studs to each wheel. otherwise its visually the same.
obijuan is offline   Reply With Quote
Old 08-16-2012, 08:43 AM   #18
blazerboy_4life
70Custom10
For as much as everyone loves pictures on this forum I expected a better response. Oh well. Thanks anyway everyone.
Old 08-16-2012, 01:28 PM   #19
haysonj
haysonj's Avatar
Not a two wheel drive but here is a short fleet 3/4 ton 4x4 It has a 14 bolt rear dana 44 front T400, 208 transfer and a Gear Vendors OD with 12.50 x 35 tires
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-16-2012, 02:42 PM   #20
davepl
davepl's Avatar
Well you should definitely adjust the spring rates to be appropriate for the reduced weight if you shorten one.
The 3/4T trucks have a taller and more substantial cab mount, which should actually improve the ride (if all else were equal) over the 1/2T trucks.
I for one am glad mine's a 3/4T, as I work my way back through reassembly, everything in the shop manual reinforces the fact they're just better built. I can't count how many times I've seen "Torque to 120ftlbs (210ftlbs for C2500)" and so on.
Of course they're probably worth less, as the trucks "catch on" with the collector market they're still looking for shortbox man-cars.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-16-2012, 02:51 PM   #21
sameyrasmea72
sameyrasmea72's Avatar
before and after.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-16-2012, 03:47 PM   #22
blazerboy_4life
70Custom10
I gotta tell ya that truck puts a smile on my face! Ive always loved the orange and white. Your truck is no exception! Was it difficult to shorten?
Originally Posted by sameyrasmea72 View Post
before and after.
Old 08-16-2012, 03:55 PM   #23
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup... also the pinion hits right in the middle of the ring gear, where a 12 bolt and Dana grab the ring gear lower on the ring. It was either Moser or Strange that offered a 9" 3rd member with a 12 bolt pinion style. So you could run the 9" housing and not have c-clips, but have the strength of the where the 12 bolt pionion grabs the ring.
You're asking for a needle in a haystack. Just ain't gonna be many around. I'm sure cats have done it... but very few.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-16-2012, 05:52 PM   #24
sameyrasmea72
A friend of ours bought the original truck from us and shortened it. He cut the frame and cut down the bed too. I not sure how difficult it was but he is pretty handy with that sort of stuff.
72 Cheyenne Super
Old 08-18-2012, 04:22 PM   #25
blazerboy_4life
70Custom10
Needle Im sure but with--
Members: 98,335
Threads: 452,777
Thats a lot of trucks and even more of us have more than one. I figured there would be at least a couple people out there who have done it. The 4x4's are cool too so we can keep those coming.
Gary
3/4 ton, conversion
