Just a car guy
Avoid American Autowire Alternator conversion
I ordered an external to internal regulator wiring conversion kit by American Autowire. Installed it, and installed the new alternator.
After connecting the battery cable, the alternator started smoking. I ended up cutting the conversion plug open that connected to the external regulator wiring. According the posts on this site, you only jump the two outside wires together. The conversion had this, but also had the two wires in the middle jumped together. The white wire, at the alt, which is supposed to be unused, was going to plug 2 on the alt. According to this site, plug 2 should be jumped to the post on the alt. Luckily this only destroyed the alternator, and did no cause any damage to the truck. I pulled it off, and rewired based on the posts I have seen here. Its good now.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
Re: Avoid American Autowire Alternator conversion
I found a simple way to wire it right at the regulator plug, someone on here posted a how to for this and it worked perfect and cost nothing, except for the new alternator of course. Took about two minutes to cut and splice a couple wires.
http://smg.photobucket.com/albums/v655/aaronhero/ |
Just a car guy
After going through this, I found the thread here that showed how to do it as well.
#4 | ||
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
All I know is I bought an American Auto Wire HEI tach harness and the plug they put on for the tach connection is the wrong one. It won't plug in w/o modifying...so what's the point? I've made my own tach harnesses until this one. I was just hoping for a factory look. It's enough for me to go elsewhere for my wiring needs.
Subscribed......first bad rap i've heard about AAW.
Most seem to love their full wiring harness kits. Posted via Mobile Device |
Moderator
![]() Join Date: May 2007
ive never had an issue with americanautowire. i have used their headlight, engine, cab, tach, and speedwarning harnesses, and they are all identical to OEM in every way.
tim- what was wrong with your HEI tach harness? mine have all had the correct wiring and firewall grommet. perhaps they sent you one with the OEM horseshoe connector? thats all i can figure, the HEI one i have from them is the correct plugstyle connector and hooked up with no problem. Posted via Mobile Device
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I'd have to show you a picture,probably. But,the connector is "almost" right. It just won't push into the cap. There is a rib on the distributor side of the connector that keeps it from working. I'll have to shave it off. It could be worse,but just darned aggravating trying and trying to click it in leaning over the engine before realizing it just won't go. I just changed the cap and it still won't go. I'll change my mind,but right now they're on my bad list.
Just a car guy
All I know is I pluged mine in, connected the battery cables, and the alternator started smoking. Disconnected it, verified installation, got new alternator, connected battery cables, and smoked another one.
Removed it and wired according to thread here, got new alternator and its all good now, no smoke.
#10 | |
Just a car guy
Maybe not, but the truck was fine with the stock alt, replaced it witha 63 amp internal, and the AAW harness. Smoked the alternator, chenged alternator, smoked it too. Dissconnected the harness, wired the truck based on thread here and it worked fine. No other changes.
#11 | |
![]() Join Date: Sep 2011
Just found this out today also........ ![]() They put the "batt" terminal on the brown "tach" wire !!!! Ugh,,,,,,,,
1967 C10 SWB Owner - Rustbelt Restorations |
#12 | |
