Old 10-03-2003, 10:42 AM   #1
RRed67
backspacing ???'s
how much backspacing can I go before hitting the frame????
RRed67 is offline   Reply With Quote
Old 10-03-2003, 10:58 AM   #2
SCOTI
SCOTI's Avatar
I had a 15x14 custom steelies w/31x18.5 MT's under my 67short fleet. The only frame mod was removal of the factory bumpstop & bracket on the outside of the frame. It might actually clear; the main reason I removed it was for clearance when it was lowered.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-03-2003, 12:18 PM   #3
RRed67
have any pics??????
Old 10-03-2003, 12:23 PM   #4
gr8scott51
gr8scott51's Avatar
lots of threads
There have been lots of threads on this, try running a search on backspace. Stock is 4-1/2".
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 10-03-2003, 03:57 PM   #5
SCOTI
SCOTI's Avatar
The only pics I have are from years ago & My scanner doesn't want to scan them for some reason. It looked like a typical pro-street truck, the main difference was I used offset wheels instead of narrowing the rear-end. I didn't want to narrow the rear because I knew eventually I would step up to big diameter wheels.... which I did.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2003, 01:43 PM   #6
RRed67
SCOTI how much offset did you use???????
Old 10-06-2003, 04:07 PM   #7
Frank_Zeller
Frank_Zeller's Avatar
Pretty sure the stock 15 inch steel rims are 3.5 offset. I've run 15 inch 4.5 offset rims with no problems.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 10-06-2003, 08:06 PM   #8
SCOTI
SCOTI's Avatar
15x14 w/10" b.spacing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-06-2003, 10:01 PM   #9
butter
butter's Avatar
SCOTI
If I make the frame mod and put some bigger tubs in the bed of my fleet side I should be able to run a 31x18 tire with out rubbing the frame. I do not have to move the trailing arms are anything else is that right.
71 cheyenne 402 th400 swb
71 camper special (PARTS TRUCK)
70 Stepside swb 350
butter is offline   Reply With Quote
Old 10-06-2003, 11:59 PM   #10
SCOTI
SCOTI's Avatar
The trailing arms remain stock.... you just can't use lowering blocks w/this set-up. I widened my tubs to the frame rail. I also had to tweak the e-brake cables so they wouldn't contact the wheels but that was pretty easy.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
